It is currently Mon May 04, 2026 2:06 am
 Post subject: suspension help
PostPosted: Sun Aug 11, 2013 2:04 pm
Needing help with my front end. Im buildng a new buggy I have a six inch over beam with 4x1 trailing arms and combo spindles on a berrian worrior frame. The thing is now is what shocks to run can I run a fox air shock or do I half to run coilovers and what kind of travel 10 12
 Post subject: Re: suspension help
PostPosted: Sun Aug 11, 2013 2:37 pm
I have put several sets of coilovers on buggys and work awesome. The springs and valving it the main key to coilovers if coilovers are in the buget I would run them. I can have a new set of kings with remote resivours shipped to your door for around 1100 ready to bolt on and ride like a dream. I have no experience with air shock so will need someone to chime in who has them. I love my coilovers and hrs and hrs of valving and spring rates I would go to nothing else since I finally have them figured out . My 2 cents
PostPosted: Sun Aug 11, 2013 2:38 pm
10inch travel
PostPosted: Sun Aug 11, 2013 3:12 pm
Thanks a lot for the info one more thing the coilovers I was looking at are the same price for 10 and 12 inches of travel would it be worth it to go ahead and get the 12 inch or would i not use the full potential of the shock
PostPosted: Sun Aug 11, 2013 4:06 pm
No you won't use all of the 12inch shock. Get 10s for your set up.
PostPosted: Sun Aug 11, 2013 4:12 pm
Does the beam have shock towers on it? If it does I'll be willing to bet 10" travel shocks. If not you should consider a few more factors. The front wheel travel is limited buy the tie rod sleeves in between the upper and lower frame rails. Set it up where there is about an inch or so between the sleeve and the bottom frame rail with the wheel turned away from the frame.
Stroke the arm up so the sleeves miss the upper frame rail while measuring the travel at the lower shock mount If it's more than 10" go to a 12" shock.
Like Buggybarn suggested coil-over shocks are the best once they are set up right. Most don't have the budget for them so Fox air shocks are a good second option.
PostPosted: Sun Aug 11, 2013 5:26 pm
I'll be making my shock towers off the frame
PostPosted: Sun Aug 11, 2013 5:53 pm
I sent you a pm
