It is currently Mon May 04, 2026 2:52 pm
 Post subject: Mid shift 6 rib ?
PostPosted: Wed Jul 31, 2013 12:37 pm
Found a mid shift 6 rib.
Code ABD12104
Any good and what's it worth?
 Post subject: Re: Mid shift 6 rib ?
PostPosted: Wed Jul 31, 2013 12:44 pm
2 spyder diff, wide gears, 483 ring and pinion 1983-1985. If things have been ripped off of it for example slave cylinder, front mt, throw out bearing , chances are they were used for the replacement trans and what you MAY have is a busted core. Junkyards can sell you one and not even know it is a core. ALWAYS remove bell housing and inspect.
PostPosted: Wed Jul 31, 2013 1:49 pm
It's still in the 85 bus. Nothing taken off everything is there, motor and all. What else should I get while I'm at it.
PostPosted: Thu Aug 01, 2013 6:34 pm
make sure and get ALL the brackets, mounts, shiftball... EVERYTHING. the trans is easy to come by, all the little parts that go on it are not 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Thu Aug 01, 2013 10:26 pm
What he said!!!!!!
