It is currently Tue May 05, 2026 1:12 am
 Post subject: bad miss
PostPosted: Sun Jul 28, 2013 9:59 am
devloped a bad miss on my buggy i was useing it to jump my lawn mower off.like a idiot i had the jumper cables hooked up backwards.it was running fine before that.i have replaced the points and condenser and plugs.do yall think it might be the coil or the switch.any ideas thanks.
 Post subject: Re: bad miss
PostPosted: Sun Jul 28, 2013 10:15 am
If you have a bad miss in your buggy, make her get out.lol I'd pull up air cooled vw coil testing and get a $15 voltmeter at Autokazone. If ya need a new one, yall correct me if I'm wrong, you need a coil without an internal resistor for a vw? Check your switch and battery also with the voltmeter.I keep one on my dashboard permanently.
PostPosted: Sun Jul 28, 2013 10:16 am
Is it still charging??
PostPosted: Sun Jul 28, 2013 11:34 am
yes its still charging everythings ok cept for the miss and at higher rpm it seems to smooth out.
PostPosted: Sun Jul 28, 2013 11:53 am
If it smooths out at High RPM, it sounds like an intake leak. Spray some starter fluid all over the intake boots and see if the idle goes up or down. If so, you have an air leak.
PostPosted: Sun Jul 28, 2013 11:54 am
My coil was hooked up backwards when I got my buggy. It had a bad miss and was hard to turn over and start. Put a new one on and hooked up right ran great. I would think jumping it backwards would be about the same. I did hook it up right same thing and it would get very hot fast maybe after 2 mins of running.
PostPosted: Sun Jul 28, 2013 5:36 pm
just checked coil with a meter it reads ok.gonna check switch if not that maybe plug wires
PostPosted: Sun Jul 28, 2013 8:48 pm
Yankin on plug wires can be a culprit. I have a bent welding rod 3/8" L shape at the bottom to get under the bottom of the spark plug end. Lick your fingers and touch each exaust at the head and see which one ain't so hot. Then trade wires around. Take the bad boot off and clip a 1/2" off and re screw if your brand will let you do that.
PostPosted: Tue Aug 06, 2013 10:57 pm
got it running like a top again.after a complete tune up it was a clogged up idle jet after all nothing electrical after all. :P
