It is currently Sun May 03, 2026 5:38 pm
PostPosted: Tue Jul 16, 2013 7:31 pm
Made air cleaner covers for my kadrons. Cut up some jagermeiter ice buckets to fit what you guys think?
PostPosted: Tue Jul 16, 2013 7:32 pm
PostPosted: Tue Jul 16, 2013 7:40 pm
it's cool except the bolts on the top WILL leak water. Try to find a way to secure them at the bottom of the cover
PostPosted: Wed Jul 17, 2013 7:19 am
yeah I agree. the bolt pulls the cover down so water will pool in the center and slowly leak in. I just need to deal with these till I can come across a canister filter.
PostPosted: Wed Jul 17, 2013 9:07 am
Rubber washer works. I have use to left over oil cooler washer . They seem to work out good.
PostPosted: Wed Jul 17, 2013 9:39 am
The old style faucet washers work really well for this kind of application. They are made from hard rubber and will not compress easyly.
PostPosted: Wed Jul 17, 2013 10:05 am
Ok ill try that. I also thought about smearing grease all over the nut and bolt.
PostPosted: Wed Jul 17, 2013 12:07 pm
http://www.enginaire.com/
There are several of us that use them with great success.
PostPosted: Sat Jul 20, 2013 2:54 pm
. Are you guys running separate filter and adapters on each carb or getting a cover with venturis built in and running a snorkle type system? And where did you get the actual adapters?
if it aint broke don't fix it
PostPosted: Sun Jul 21, 2013 1:13 am
One filter, and what's a carburetor?
PostPosted: Sun Jul 21, 2013 10:21 am
Image ran this set up for 2 years...carbs were clean as a whistle inside...
