It is currently Sun May 03, 2026 5:38 pm
PostPosted: Tue Jul 09, 2013 10:12 pm
I know these are:
1.impossible to find
2.no one has actually ever seen one
3.would be very weak....
4.WHY would you want one even if you found it.....
but.... does anyone have a 5.42 R&P for a 3 rib.
John 3:16
PostPosted: Wed Jul 10, 2013 7:16 am
My dad runs a 3rib 5.42. He has an 1835 and 38 buckshots. It's held up really good the last two years
PostPosted: Wed Jul 10, 2013 11:04 am
I used to be King Dingaling for supplying them. I learned they were great if you stuck with 33 or smaller tires but if you ever pull someone out of a mud hole you could expect them to last 2.5 rides later to break. I had a friend in the military that would round them up at junkyards and ebay in Europe especially England. Shipping is out of the question. $600 /trans. Military members can have things shipped cheap. I was in the Air Force and flew to Europe 3 or 4 times a year. I'd have up to 8 at a time in the cargo section of the aircraft. When I'd get back I'd have 542's 456's etc but the best trophies were 094 5 speed side shifts. They last about 6 years with extreme abuse. They have 483 and 486 ring gears with 411 first, 233 second and so on. Some had 4 spyder diffs. The last 3 rib nose shifts had 542's already in them (1979).1980 and up, 3 ribs were side shift on the nose. I'm retired now but those were some great days. Imagine rows of vanagons and busses with untouched trans. The junk yard man would lift them 6 feet in the air and he'd torch the trans mt's and cv shafts after I dropped the motor. They were $100/trans. In the back of the Air Force van were golf clubs , golf clubs, trans , golf clubs.lol Try www.ebay.co.uk
PostPosted: Wed Jul 10, 2013 1:11 pm
They are actually good cause it means your 3 rib is 091 mats dads is 091 3 rib running 38 inch tires and holds up I run a 542 in my 6 rib with 38 tires and is holding up
PostPosted: Wed Jul 10, 2013 6:41 pm
The only 3 rib 002 with 5.42, I've seen was very near the end of the 3 rib production line, just a few months before the 5 rib came into production.
They are just as strong as the 6 rib 5.42, but impossible to find.
I have one, but it has all aftermarket weddle 1 thru 4 gears and is going into that 1 seater I bought from you Crambo, someday.
PostPosted: Wed Jul 10, 2013 9:47 pm
Back in the day if the trans blew up the stealer uh dealer would replace it with a 542. 538's stopped in 1973 in the U.S. (jan of 74 I guess), but kept going around the world. Towards the late 70's the buses had 542 nose shift 3 ribs in the rest of the world. Our bigger motors and highway speeds called for different ratios and strenghths .542's work well but DON"T pull anyone. To my knowledge me and Busby installed the 1st one in Alabama in my buggy back in about 1994. The most my foot (gas pedal) ever got along with a 538 was about 2.5 rides.I had busted 538's stacked up like cord wood. But that was the good ole Go or Blo Chilton County days. I believe you need a new 091 pinion bearing and chromoly pinion nut to stretch their life expectancy, with locktite. A propane torch will loosen the locktite. Do not use threadlocker or it will never come off in case you have to go into it again.I always used the monkey snot gear dope so the gears would stay sticky while climbing and so gears can slow down enough to change without grinding.
PostPosted: Thu Jul 11, 2013 9:11 am
I new it was a long shot to find one, but it neve hurts to ask. It's actually for my granddad. we put a set of those 33 terminator atv tires on his buggy(they go like wild in the mud and soft stuff), he loves the tires but would like to gear back down...he's about 74 and likes to take it easy in the woods in his two seater....he save the bigger stuff for his one seater :) Anyhow i told him we might round him up a six rib and drop a 5.42 from weddle in it or something. Maddog you ain't never going to get that one seater built while running around on your new trike all day :D I need to show Denny your pictures I told him you had already had more fun on that thing than him.
John 3:16
PostPosted: Thu Jul 11, 2013 11:32 pm
Yeah, it's neat to pull in somewhere to stop and watch all the cameras come out.
PostPosted: Thu Jul 11, 2013 11:45 pm
I run a 5.38 ring and pinion in my SS with 1st through 3rd weddle gears. I beat the crap out of it and it holds. Knock on wood.
PostPosted: Fri Jul 12, 2013 1:33 am
I have one, I pulled it out of a 3 rib that has the acorn nuts on the sides holding the stubs in.
PostPosted: Sun Sep 15, 2013 10:18 am
gotone I'll sell. put in buggy and broke 1st gear. pulled bell housing made sure diff and r&p not hurt. tranny still together. in double springs AL -205-489-9461
ride hard--------pay latter!
PostPosted: Mon Sep 16, 2013 8:50 am
weddle had some used ones for around 300 bucks shipped I believe
