It is currently Mon May 04, 2026 4:32 am
PostPosted: Sun Jun 30, 2013 11:54 am
Fuel cell, stainless or aluminum gas tank
Big valve DP heads with stainless steel valve (94mm)
Stroker forged crank in good shape (.10 is ok)
94mm pistons/jugs
lightened flywheel etc
PostPosted: Tue Jul 02, 2013 7:40 pm
magic city VW.. over off crestwood blvd, in the same shopping center as home depot all the way in the back
smallfry imports.. 38-3900 block of 1st ave n
jesse made a post a few weeks ago of several sets of boggers our buddy has for sale in moody.. all good tires on rims, they just sitting in the weather ruining.. he also has several engine parts you may be looking for
hope this helps 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Jul 02, 2013 7:59 pm
Yeah, I am picking a set of headers from David tomorrow. :D
PostPosted: Wed Jul 03, 2013 6:37 pm
i have a hole front end with new shocks and barings with tires and asking 200 OBO for them
PostPosted: Thu Jul 04, 2013 11:18 am
Thanks but I would be interested in it had brakes or if you also had the rear wheels.
PostPosted: Sat Jul 06, 2013 7:25 pm
Today was a good day, I scored 2 almost new v-tread 31/15.5-5 tires mounted on chrome rims, 40mm carb with intake, set of rear brakes, 2 seat covers (pristine condition), 2x baja claws tires 32-12.5-15 (20-25% left), 4 puk clutch, dp heads, external oil cooler kit, generator, set of stock pistons, etc etc for $320.
PostPosted: Sat Jul 06, 2013 10:07 pm
great deal but watch out for hidden metal particles in an oil cooler after a motor has blown up or stripped cam gears etc. Hopefully a filter caught it all if it had one.
PostPosted: Sat Jul 06, 2013 11:32 pm
Yeah, I should be fine but I may buy a new cooler. The deal came with a complete motor with the 40mm carb. The pistons are like new (92mm). The block is a goner and had probably 1/8" play at the crank. Has good lifters, cam, and 041 heads that bench tested good (no leaks). Looked like the engine was not driven a lot, needed a align bore really bad and had a .030 crank that most likely I won't be touching. I rather go with a new forged crank.
