It is currently Tue May 05, 2026 1:08 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
PostPosted: Mon Apr 29, 2013 9:41 am
Like the Title Says... What fuel do you run in your buggy?
I have always used pump gas (93) in all my buggies but the new buggy takes 110. It took me a little while to even find a place that sells 110. Anyway, I was just wondering how many people are running Hi-Octane fuel.
PostPosted: Mon Apr 29, 2013 10:06 am
111. 118 mix with 93 just cause we got a couple (55gal) drums left over from racin
PostPosted: Mon Apr 29, 2013 12:46 pm
Whatever racing fuel I can find near where im riding
PostPosted: Mon Apr 29, 2013 1:43 pm
Regular old low octane fuel, fuel injection and and ECU make inexpensive fuel do great things
PostPosted: Mon Apr 29, 2013 2:45 pm
Air cooled suckers pay through the nose one way or another. :P
PostPosted: Mon Apr 29, 2013 4:53 pm
I used to race quads and from what klotz racing fuels have told me when i got my race gas at the nationals is that mixing 93 with high test cancels out the high test basically im going to try an find this write they did about on it and post it .
PostPosted: Mon Apr 29, 2013 5:25 pm
Only 111 octane $60 for 5 gallon can or $8 a gallon at the pump
But it does smell good when its running
PostPosted: Mon Apr 29, 2013 6:40 pm
WB Competitor
93 with sea foam. kept compression at 10 and a half to 1 so i dont have to pay the price for the 110 or 115. i ran 118 in my stock cars for 15 years and its rough on the pocket as much as we ride with 3 buggys.
PostPosted: Mon Apr 29, 2013 7:04 pm
I run 93 pump gas in my Turbo Subbaru 2.5. I keep the boost under 8PSI due to the the 10.5:1 compression.
PostPosted: Mon Apr 29, 2013 7:41 pm
I always ran 94 , but new motor is race fuel only, gonna see how rough it is on me this year might drop the compression over winter depending.
"IT IS WHAT IT IS"
PostPosted: Mon Apr 29, 2013 8:01 pm
i think if 60.00 for can, or 8.00 at pump with same can, i would go to pump.
PostPosted: Mon Apr 29, 2013 8:29 pm
The place near my house sell 110 for $9.80 per gallon. If you buy it in a 5 gallon can, you have to pay an extra $10 for the can. I just bring my own gas cans and they fill them up.
PostPosted: Mon Apr 29, 2013 8:56 pm
The cheapest 87 octane I can find. Nearly 300 hp and probably 25 mpg.
PostPosted: Mon Apr 29, 2013 9:51 pm
Well I would rather buy pump racing fuel but its about 40 miles to
that store and about 8 miles to the store with 5 gallon cans so it
depends where I riding on which one I get
PostPosted: Mon Apr 29, 2013 10:45 pm
110 sunoco
PostPosted: Mon Apr 29, 2013 10:51 pm
I run 100ll in one seater and just finishing refresh on two seater. I lowered compression to 9.5 to 1 so I can run pump gas.
PostPosted: Tue Apr 30, 2013 2:58 am
unless he has a different buggy that I haven't heard about, no need for preaching that w/c shit cause his has a turbo subie in it already :roll:
PostPosted: Tue Apr 30, 2013 3:02 am
and for the record mostly I run 110 monster brand gas out of the pump , at $7.00 gal.
PostPosted: Tue Apr 30, 2013 11:09 am
10-4 Chris, no thin skin allowed. I knew that and that's why I said what I said. My new 2.5 Subaru requires me to run 93, not exactly the cheap stuff but compared to race fuel it isn't so bad.
PostPosted: Tue Apr 30, 2013 2:36 pm
I wish mine would run on 93... this 110 stuff is expensive.. Where do you find $8.00 a gallon? I need to go there.
PostPosted: Tue Apr 30, 2013 3:43 pm
I know that Forty isn't lying I can verify the fuel millage. I use one gallon for every two my buddies air cooled air compressors use.
Mouse I think fuel is cheaper in Tennessee and Kentucky for some reason
PostPosted: Tue Apr 30, 2013 7:01 pm
the ashville/pell city exit off of I-20 between bham and anniston has 114 for $7.99 a gallon :mrgreen:
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Apr 30, 2013 7:33 pm
Go to the airport and get AV gas I ran it for 25 years in all my high compression buggy motors I added a little Marvel mystery oil for cylinder lubricant because it is a dry fuel .When I freshened my engines they always looked good and clean.6 bucks a gal around here.Did I mention I ran it for 25 years
PostPosted: Tue Apr 30, 2013 8:28 pm
Note: the key to AV gas is top oil, Marvel Mystery Oil
PostPosted: Tue Apr 30, 2013 8:50 pm
I run a "Davis Motorsports" bulit 2276 with 9.7:1 comp.I always buy 93 oct. gas at the pump and I add 1/2 a bottle of "Lucus Oil" Octane booster(a whole bottle treats 60 gal. if i rem correctly) and i have a 11 gal tank i think....Smells like "Buggyjuice" ! 8)
