It is currently Sun May 03, 2026 8:25 pm
 Post subject: 6 rib build opnions?
PostPosted: Mon Apr 22, 2013 12:37 am
i have a 6 rib that will not go into gear just pops at the flanges not sure whats wrong with it was thinking about tearing it apart but have never done one before wondering if its simple also wanting to build it so its stronger wanting to know what is best parts to build with for money wanting stronger fist secound and reverse and maybe stronger dif? running a 2.2 subaru this will be third tranny within 2 years first tranny reverse went now this one im not sure just wanting good reliable tranny cause 6 ribs are not cheap to come buy thx ahead for all info
*subiepower*
 Post subject: Re: 6 rib build opnions?
PostPosted: Mon Apr 22, 2013 12:57 am
If you want a reliable Trans.. I would call Chuck Jones.. You will know that you have a correctly built trans and he can usually rebuild your trans cheaper than you can buy the gears.
PostPosted: Mon Apr 22, 2013 7:16 am
Call Chuck Jones, it sounds like a bad ring and pinion.
PostPosted: Mon Apr 22, 2013 7:19 am
go to a vanagon side shift trans the 6rib no matter what you do rev is still weak i all so run a 2.2 with some cam work i have a 85/86 vanagon with a super diff and love it been in there for 6 years and no problems
PostPosted: Mon Apr 22, 2013 9:12 am
Pop the bellhousing and check, the spider gears are generally the weakest point, 1st to break.
PostPosted: Mon Apr 22, 2013 12:46 pm
Unless you have a source to borrow the specialty tools it's cheaper to have it done. If the pinion bearing needs replaced it requires 2 real special tools. Just sayin! :wink:
PostPosted: Mon Apr 22, 2013 5:48 pm
x2
the only 6 rib r&p's ive seen broke were due another to another failure such as a bad bearing, stripped/loose pinion nut, or broken carrier
PostPosted: Mon Apr 22, 2013 6:26 pm
ok well maybe i will give chuck jones a call and see how much he can do one up for me thx
*subiepower*
