It is currently Sun May 03, 2026 3:09 pm
 Post subject: Ignition (no spark)
PostPosted: Sat Apr 06, 2013 12:17 pm
He guys, I have some gas in the buggy... trying o get it to start... It turns over and never tries to fire... I opened up the carbs and I can see gas in them and if I work the cross bar I see gas spray... so I can only assume that they are OK (I do smell it too)... However I pulled a plug and stuck it in the plug wire and held the electrode to the frame and I see no spark... tried two different plug wires to be sure and nothing... so might be on to something... I tested the coil and it falls into spec with my meter... the distributer is a 009E with a pentronics module in it (its an all black module so may be knock off)... I bought this a long time ago with the understanding that it should work. well not so sure right now... can you folks tell me how to test? I do see this:
http://www.ehow.com/how_7993715_do-test-pertronix-ignition.html
I just so happen to have an old 009 distributer in the garage, has points, but no condenser... so I don't think they cost a lot... going to run down the street and pick one up. I am about as broke as I can be right now... so if its not thins I will be stuck wondering... But with points I will be able to see the spark...
thoughts?
 Post subject: Re: Ignition (no spark)
PostPosted: Sat Apr 06, 2013 12:27 pm
i would say it is your ignition or if u have a msd box it could be that to
PostPosted: Sat Apr 06, 2013 12:33 pm
make sure you have power to the coil while your cranking. a bad ignition switch could cut ignition power while cranking. to check your electronic ignition just put a test light on both terminals of the coil it should flash while you crank it. also take your cap off and make sure your rotor is actually turning.
PostPosted: Sat Apr 06, 2013 12:41 pm
Going to try the following:
This coil you are using, is it from a VW? If not, you should check that the primary coil resistance is in the 3-4ohm range. You do this by:
Remove all wires from the coil
Set your multimeter to read resistance (ohms) at the lowest range (<20 ? )
Place one test lead on the + terminal and the other on the - terminal
You should read between 3 to 4ohms of resistance between the two terminals
Move the test lead from the + terminal to the large center terminal and set your meter to read in the 20K range. You should get a reading in the 7K to 10Kohm range.
Now, how can you test your coil?....
Connect the 12v+ source to the coil + terminal
Insert the coil wire into the center post and hold the other end near a ground, 2mm should be good (distributor cap clamps make a good ground). You may want to use insulated pliers for this.
Using a jumper wire, connect the coil - terminal to ground for 1 second and then remove the wire from the terminal. When the wire is removed, a spark should jump from the center coil wire to ground.
If that worked, your coil is probably good.
Next, rotate the engine until the ignition points are closed.
Connect the green wire from the points to the coil - terminal.
Using a plastic or wood stick, push the point contacts apart. The center coil wire should spark as the points open. This tests that the points are properly grounding when they close.
If the coil sparked with the jumper wire but not with the points, suspect the points or condenser.
PostPosted: Sat Apr 06, 2013 4:53 pm
I have points and condenser in and now I am getting some popping and whatnot from exhaust... Can you folks tell me where the plug wires go on the distributor... I thought I knew but might be wrong since its not starting...
I put the distributer on #1 cyl (rotor pointing to #1) and on the Dist. cap at that location have #1 plug wire going there... next one going clockwise is #4, then #3 then #2... Is this wrong? If so what should I di?
Also have condenser wire going to the neg. side of the coil (-1) and coil wire going to positive side (+15)
I have valves set to loose 0... should I change that?
please let me know...
PostPosted: Sat Apr 06, 2013 4:57 pm
for #1 cyl on dist rotor shold point more tward the fule pump
PostPosted: Sat Apr 06, 2013 5:30 pm
Hmm so get rotor at #1 direction and then start #1 plug wire on the next spot?
like this (even though #1 plug TDC would be where #2 is?)
PostPosted: Sat Apr 06, 2013 5:36 pm
dont even worry about rotor just put wires like the picture
PostPosted: Sat Apr 06, 2013 5:48 pm
OK I have them just like the pic, and it pops some but will not start... thoughts?
PostPosted: Sat Apr 06, 2013 5:58 pm
might try turning dist alittle timming might be off
PostPosted: Sat Apr 06, 2013 6:07 pm
Yeah I have tried, turned a little to the right (clockwise) and no good... as it is in the pic it pops through the carbs, if I rotate it a lot it will pop from exhaust. You think my valves are off... and how can I tell for sure they put the dist. drive back in the right way?
PostPosted: Sat Apr 06, 2013 6:18 pm
if the dist is seated all the way down its in right.get the mortor to tdc on #1 cly and your rotor button should point to #1 plug wire on dist.
PostPosted: Sat Apr 06, 2013 6:33 pm
hmm...
OK if I have the piston up and rotor pointing to it (#1) how can I tell its not 180 out? I loosened the valves and I see intake and exhaust are really tight and the exhaust on #2 is loose and the intake is tight. If I rotate it 360 Deg. so the rotor points to #4 than the intake and exhaust are loose on the #1 piston... but the rotor is pointing to #4.
PostPosted: Sat Apr 06, 2013 6:52 pm
you can turn the motor a little if ex valve on #2 cly rocks back and forth your on top dead center #1
PostPosted: Sat Apr 06, 2013 6:55 pm
rotor should point to post on dist where #1 plug wire is
PostPosted: Sat Apr 06, 2013 7:33 pm
its 180 out... I rotated to TDC and made sure it was the right one by rocking the pulley and seeing the exhaust on #2 rocking... then I set the valves to loose 0.
Now to make sure the plugs are on right... do I pit #1 cyl on the #3 location and then going clockwise 4,3,2 ?
I did that and it tries to start up but there are lots of backfireing and such...
PostPosted: Sat Apr 06, 2013 7:56 pm
that dont sound right but where ever the rotor is pointing with #1 at tdc #1 plug wire would go there and then 432
PostPosted: Sat Apr 06, 2013 7:58 pm
did you try and reinstall the dist?
PostPosted: Sat Apr 06, 2013 8:13 pm
Your gear does not have to be in the right place. I would pull the covers pull up tdc see what intake and exhaust is closed then put your plug wire on the one the rotor is on. Do this on all 4 then I would do the timing test light then I bet I will fire up
PostPosted: Sat Apr 06, 2013 9:17 pm
I got it running... I pointed the notch in the distributor to #3 as well as the rotor and then put the plug wires in starting with #3 as #1 plug, then 4,3, and 2... it started first turn of the key. Now I just need to fool with the 44mm Carbs...
look for that thread next lol
was nice to see it run ;)
PostPosted: Sat Apr 06, 2013 9:48 pm
hood to hear
PostPosted: Sun Apr 07, 2013 3:14 pm
I have it idled high so it could bake the paint in... but I wanted to show that it idles solid... One odd thing, once I tuned it by ear (timing I mean) and turned it off the starter is having a hard time turning it over... you think the timing is doing that or you think the starter is not strong enough to turn it over?
thnx
PostPosted: Sun Apr 07, 2013 5:12 pm
most likely the timming
