It is currently Tue May 05, 2026 3:27 am
PostPosted: Thu Jan 03, 2008 8:13 pm
anyone help me out on how to go about cuttin the oil pan on my subie to gain some more ground clearnce thanxs
PostPosted: Thu Jan 03, 2008 8:29 pm
look on my new winter project on photos and pics . page 3 has a pic of Steves pan.
PostPosted: Thu Jan 03, 2008 8:51 pm
Steves pan looks real good. Here is what i did. Take the oil pan off and clean it up. Place it upside down on a good flat surface like concrete floor, heavy duty work table, or wifes granite counter top. I stood up a 2x4 on its side to equal 3.5 inches and laid one of those carpenter pencils on it so the lead sticks out the side.This is a way to get an equal mark all the way around the oil pan that is about 3 5/8 inch. Bring the oil pan to the pencil and spin it around until you get a mark all the way around the pan then cut it off with a chop saw or whatever. Then you have to build a bottom from 1/4 flat steel. But before you weld the bottom on you have to alter the oil pickup. I cut mine into and removed some and then welded it back together. With the bottom still off make sure the pickup is about 1/4 lower than the bottom when it is on the upside down motor. It helps to use a motor stand. 8)
PostPosted: Thu Jan 03, 2008 9:11 pm
See I knew firebug would know. He knows subies, His runs great
yea WC WC WC
PostPosted: Thu Jan 03, 2008 9:54 pm
[img][img]http://i223.photobucket.com/albums/dd87/jem203/100_0301.jpg[/img]
I cut mine at 4 inches the same way firebug did it. I cut 2 1/4 inches out of the pic up and leaned it forward about 1/4 inch. I'll post pics of the pan and pickup later. I used 3/16 steel for the floor.
[/img]Image
[img][img]http://i223.photobucket.com/albums/dd87/jem203/100_0303.jpg[/img][/img]
PostPosted: Thu Jan 03, 2008 10:32 pm
how much lower does subie set than vw :?:
PostPosted: Thu Jan 03, 2008 10:37 pm
bout 1.5 inches,,,or something :?
PostPosted: Thu Jan 03, 2008 10:38 pm
well heck that's not much
PostPosted: Thu Jan 03, 2008 10:40 pm
Rock,,,that is after modifications. :wink:
PostPosted: Thu Jan 03, 2008 10:42 pm
I know that duuuu
PostPosted: Thu Jan 03, 2008 10:43 pm
is the page real wide or is it just me
PostPosted: Thu Jan 03, 2008 10:58 pm
my pics must be too big?
PostPosted: Thu Jan 03, 2008 11:07 pm
Just remember to put in a drain plug :roll: and cut the new floor bigger than it needs to be, it will leave a shelf to weld to.
PostPosted: Thu Jan 03, 2008 11:19 pm
thanxs for alll the help guys, i understand the pan part do you have any pics of the pic up
and when you say the pic up should sit lower than the bottom of the pan do you mean
top of motor when upright
--------------------------------- pic up "A"
____________________ oil pan bottom
---------------------------------- pic up "B"
what i mean by the "B" is should it be 1/4 inch below so when i bolt the pan on it should push the pic up a little as you tighten the bolts
or "A" when bolted on the pic up should have about 1/4 inch of space between the bottm
thanxs for all the help
PostPosted: Thu Jan 03, 2008 11:27 pm
when the engine is upside down on the engine stand the pickup should be lower that the cut pan so when you put the bottom on it will clear the bottom.
PostPosted: Thu Jan 03, 2008 11:30 pm
1/4 in of space between the pickup and the bottom of the pan so oil can get sucked up into the pump. I'll be doing this to mine shortly. I plan on welding a piece of rod across the bottom of the pickup so if it ever gets knocked it won't close off the pickup.
http://www.outfrontmotorsports.com/oil_pan.htm#Oil%20Sump
John
