It is currently Sun May 03, 2026 3:17 pm
 Post subject: 2.5 turbo
PostPosted: Wed Mar 13, 2013 6:04 pm
will a stock 6 rib hold up to 2.5 turbo or should i install super diff initially?
 Post subject: Re: 2.5 turbo
PostPosted: Wed Mar 13, 2013 6:40 pm
I would say that a super diff would be a definite. A Weddle 3 & 4 gear should be in the future. :mrgreen:
PostPosted: Wed Mar 13, 2013 6:58 pm
Weddle everything especially if your going to exceed 200 HP
PostPosted: Wed Mar 13, 2013 11:14 pm
It will depend on how you drive.. If you go really easy and only ride easy trails, you will be fine with a 6 rid. If you plan to hit hills or difficult trails, you will need a super diff and weddle gears.
PostPosted: Thu Mar 14, 2013 9:04 am
Hmmm! It would seem to me that if someone intends to use a Turbo Motor in a Buggy they are not going to be be driving Ms. Daisy! :wink: :mrgreen: Super diff and 1 thru 4 Weddles minimum.
PostPosted: Sat Mar 16, 2013 12:37 am
:shock: :shock: :shock: Oh Crap... I have a 2.5 Turbo and dive Ms Daisy all over... I think I need to step up my game of get rid of the Turbo.. :oops: :oops: :oops:
PostPosted: Sat Mar 16, 2013 9:27 pm
Mouse you just take that thing for a slow drive in the woods.
PostPosted: Sun Mar 17, 2013 12:21 am
Stop it ! I shucked a many of side shifts with my Buick v6. Do not hope, guess or fathom harmony with a vw trans and a power house.My biggest problem was case flex, the gears move apart from each other then shuck. The trans that came with the motor is what you want.I know the Passat has been down for a while with a bad wire but I have not busted a trans .Diff yes.but they are cheap and plentiful at Pull a Part.
PostPosted: Sun Mar 17, 2013 2:49 pm
OK then whats the point of having all the extraBS that goes along with a Tirbo motor if your just gonna poke around thru the woods, the wow and cool factor? :roll: :mrgreen:
PostPosted: Sun Mar 17, 2013 2:55 pm
Here is my turbo buggy running against a 3 rib starting at the 30 second mark :)
