It is currently Sun May 03, 2026 12:44 am
PostPosted: Fri Mar 15, 2013 8:30 am
I have an on/off road buggy with Weber ICTs. It has the factory Redline Hex Bar linkage. I’m not happy with it and I don’t seeing it handling off road all that well. I’m looking at the SCAT linkage. Just wondering what you guys with duals use and have luck with?
PostPosted: Fri Mar 15, 2013 9:21 am
For sure the scat linkage. Less moving parts and alot cleaner looking.
PostPosted: Fri Mar 15, 2013 9:28 am
I just placed an order for the SCAT. I figured it has to be better than the cross bar. I heard you have to remove a case stud or something for the install?? What is that about?
PostPosted: Fri Mar 15, 2013 9:53 am
Ya one case stud has to be removed so you can replace it with a longer one, no biggie.
