It is currently Sun May 03, 2026 5:38 pm
 Post subject: carb problems
PostPosted: Mon Mar 11, 2013 7:57 pm
ok my carbs have always done this. first of all last week we completly broke them down and cleaned them up they run like a champ if im on top end but if im lugging up a hill and decide to get on it they wont pick up it just is verry slugish and never gets going what could cause this also they are dual webber 40's i believe my main jets are 50's
 Post subject: Re: carb problems
PostPosted: Mon Mar 11, 2013 8:06 pm
also motor is a 2221
PostPosted: Mon Mar 11, 2013 10:19 pm
Give more info on motor. If the carbs idle and run good I would look at other areas before condemning the carbs.
PostPosted: Mon Mar 11, 2013 10:24 pm
well my thought is the idles may be overdoing it on the fuel may need to change them the motor has a 80 crank 94 pistons cb044 heads 110 cam all i know about it
PostPosted: Tue Mar 12, 2013 12:13 pm
check fuel pressure then float levels. I believe you want around 3 psi... NO MORE!!! I always run the floats as low as possible. keep lowering them then run the buggy hard for as long as you can to see if you run out. once you run out, raise them up a little and leave em there.
PostPosted: Tue Mar 12, 2013 6:22 pm
456 gears and 36'' buckshots... you gotta light it up before you hit the hill jesse :roll:
for what you want it to do, your gunna have to run a lower gear (5.42) or run a single carb
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Mar 12, 2013 8:26 pm
If what Reno says is true, you need a BIGGER motor!
PostPosted: Tue Mar 12, 2013 10:06 pm
it aint the gears and tires its in the carb it also smokes black so that would be to much fuel right i think its over loading it on bottom it has 50 idles so im gonna try some 45s and 40s
PostPosted: Tue Mar 12, 2013 11:24 pm
When you figure it out let me know because my 2 seater has always done that even with a 2500 on it.
PostPosted: Tue Mar 12, 2013 11:30 pm
he will get it figured out, sounds like he already knows whats wrong with it even though he was asking for advice and ignoring what everybody is telling him, i was gonna say the same as aaron but figured it would fall on deff ears :roll:
PostPosted: Tue Mar 12, 2013 11:47 pm
reason i dont feel its tires and trans cause i ran a lower gear befor and still did this i appreceate any suggestion just talked it over with a friend and we thinking iddle jetts may not be but gonna see and i dont think i have ignored anyone :shock: also float lvls could be it i know last long hill i was on it would loose its go on a long pull
PostPosted: Wed Mar 13, 2013 12:37 am
if you know, then why ask :roll: same issue with your other buggy.. if you get it going and then gas it, it "runs like a champ on top" but if you lug up on a hill and then gas it "it sputters"... put a car in second gear, and try to take off on a hill, its gunna sputter.. same car, on the same hill with a little bit of a run and second gear will pull fine :shock: ... its the same principle :idea:
PostPosted: Wed Mar 13, 2013 12:41 am
i dont know thats why i ask lol i just said what i think it might be but want evry suggestion i can get but when i had the lower geared trans in it still did this so thats why im not thinking its my trans/tires and its not a sputter it just never gets the rpms up on bottom unless i turn it up befor i hit the hill
PostPosted: Wed Mar 13, 2013 12:45 am
just answered your own question...
PostPosted: Wed Mar 13, 2013 4:56 am
he has to make it to the woods in the first place before that can happen lol
seriously its gonna take a BIGGER motor AND a REGEARED (not just a lower r&p) tranny to even think about doing what you want with that big of a tire and a buggy that heavy
PostPosted: Wed Mar 13, 2013 3:19 pm
Was the lower geared tranny a 4.83. If so thats not enough. To fix your problem you need a 4.10 or 4.25 first gear witha 5.42 ring and pinion and that will fix the problem.
PostPosted: Wed Mar 13, 2013 3:41 pm
I dont see how youd need 45 idles i ran 50'd on my 1915 with dual 40's
"IT IS WHAT IT IS"
PostPosted: Wed Mar 13, 2013 7:52 pm
The 45s cleared up alot of the black smoke that it had on bottom dont have a hill to test it on so will have to wait and kevin that setup is my goal im putting back money to buy what I need for the trans
PostPosted: Wed Mar 13, 2013 8:17 pm
Check your air mixture screews. If you have them adjusted more than 4 turns out to get it to run your idle jets are not big enough. Borrow some 60,s and readjust your air mixture screws. Float levels have to be correct. Black smoke could be too much pump shot.
Aircooled power!
PostPosted: Wed Mar 13, 2013 8:18 pm
Ok will check that out thanks
PostPosted: Wed Mar 13, 2013 8:31 pm
They are 2 turns out whays that pump shot you mentioned
PostPosted: Wed Mar 13, 2013 9:42 pm
Accelerator pump is what he is talking about. Have you checked your timing and distributor to make sure the weights are swinging out.
Lastly check for vacuum leaks with some WD
PostPosted: Sun Mar 17, 2013 9:32 pm
If you have 40's maybe your venturis are too small. Maybe not. Do you know what they are?
Having small venturis will cause it to run rich. (not enough air)
