It is currently Tue May 05, 2026 2:03 am
Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: my winter project
PostPosted: Wed Feb 13, 2013 6:53 pm
I got the cavalier running today. I cut the wires going to the vats and she fired up. I know it's not supposed to bypass them but it did somehow. The engine sounds real strong. I'm excited about it now. I should be able to order the adapter kit, clutch and pressure plate first of march. I would buy it next week but I have a snow goose hunt next weekend:) what clutch and pressure plate should I run. Stage 2?
PostPosted: Wed Feb 13, 2013 7:13 pm
I would run a stage 2 with crush lock disc. I assume you will be running a stock size 200 mm flywheel
PostPosted: Wed Feb 13, 2013 7:43 pm
Yea 200mm flywheel.
PostPosted: Sun Feb 17, 2013 6:54 pm
Got the harness pulled from the car. Now for the fun part.
PostPosted: Sun Feb 17, 2013 9:31 pm
I run a stage 3 pressure plate with a kushlock clutch and I was able to make it slip by building boost and taking off in second gear one time. However, the clutch has been installed for several years now. Anyway, I would go with the stage 3. It's been a great clutch and pressure plate.
Huey
PostPosted: Sun Feb 17, 2013 9:42 pm
Take a look at Kennedy engineering's spec sheets then look at the engine specs the torque out put. I went with a clutch that just met my needs and would allow the clutch to slip a little at max power so as not to blast my trans into oblivion. You need a weak link some where or you will have a pile of transmissions like Passat. Some folks believe in overkill.
PostPosted: Mon Feb 18, 2013 7:02 pm
I have gave up on the wire harness. I'm not patient enough to figure it out. Engine wiring.com's website is not working so who else has a plug and go wire harness and ECM?
PostPosted: Mon Feb 18, 2013 7:48 pm
Terry fryer was a one time . Not sure if he still does them .
PostPosted: Mon Feb 18, 2013 7:56 pm
Southern Buggies, Enginewiring.com, CBM in California (They sell plug and play on eBay as well for $1000), there are others as well.
PostPosted: Mon Feb 18, 2013 7:59 pm
http://enginewiring.com/services.htm $525 TUNE ECU and wire harness.
PostPosted: Tue Feb 19, 2013 5:39 pm
I finally found a diagram for the ecu so I'm gonna give it another shot. Image
PostPosted: Mon Mar 04, 2013 8:09 pm
Got the engine pulled from the car today. Hopefully I can order the adapter plate next week.
PostPosted: Fri Mar 15, 2013 8:24 pm
Got the harness stripped and labeled. Waiting on the adapter.
PostPosted: Fri Mar 15, 2013 8:25 pm
PostPosted: Mon May 13, 2013 9:09 am
I FINALLY GOT THE ENGINE IN THE BUGGY. I STILL NEED TO FIGURE OUT WHERE TO PUT THE RADIATOR AND FUEL TANK.
PostPosted: Tue May 14, 2013 8:02 am
had to move the fuel tank
this is the box i built for the ecm.
PostPosted: Tue May 14, 2013 1:24 pm
Did you need to put a bung in your tank or is your ECO returnless? How 'bout a surge?
I wish I was still working on my engine but I got mired in this dang suspension baloney :cry:
has left the building...
PostPosted: Tue May 14, 2013 1:35 pm
i dont think i need a surge. but i might be wrong. and for the fuel return i was going to use a ''T".
PostPosted: Thu Jun 13, 2013 6:33 pm
Got the radiator mounted
PostPosted: Fri Jun 14, 2013 9:14 am
That's not an ecotec engine
PostPosted: Fri Jun 14, 2013 9:34 am
NO ITS NOT. ITS A 2200 OHV ENGINE.
PostPosted: Sat Mar 01, 2014 9:18 pm
Image The buggy is finally running and moving under its own power.
PostPosted: Thu Mar 06, 2014 12:23 pm
VIDEO or it didn't happen :D
Sent via TapaTalk
PostPosted: Thu Mar 06, 2014 1:30 pm
Haha I can't figure out how to upload the video using tapatalk. But I can tell you it is a huge upgrade from my old 1915cc. Probably double the power if not more. I just love the instant torque and the ability to just putt around and then romp on it without spitting and sputtering. Not to mention just bump the switch without having to pump the throttle.
PostPosted: Thu Mar 06, 2014 1:36 pm
https://www.facebook.com/photo.php?v=10152259959309349
cron
