It is currently Mon May 04, 2026 12:41 pm
 Post subject: Wheels and back spacing
PostPosted: Wed Feb 20, 2013 7:06 am
I need some help. Been trying to figure this out for a while. When I look at a rim for my buggy and it says 2 1/2 inch back spacing what does that mean? Where do they measure from? Im running a type 1 back end with stock arms and I want to put 31x12.50x15 tires on. Im looking at 10 inch wide rims but I dont want to have to run a wheel spacer to make them clear. Any help would be great. Thanks everyone. Figured I would go rite to the experts for good info :D
PostPosted: Wed Feb 20, 2013 7:58 am
I believe most wheels are measured from the back of the center section, where the bolt holes are, to the outer edge of the wheel.
PostPosted: Wed Feb 20, 2013 9:15 am
Put the rim on the floor outside up and stick tape measure through hole it should read 2.5" on your rims. As far as I know
PostPosted: Thu Feb 21, 2013 5:32 pm
2 1/2 on my stock wheel ? I have not ordered 10 inch wide rims yet cause im not sure what they mean when they say 2 1/2 inch back space. Does that put the wheel closer to the buggy or faurther away?
PostPosted: Thu Feb 21, 2013 6:17 pm
A 0 (zero) off set moves the wheel away from the trailing arm. A 0" (zero) offset would put the wheel center flush with the inside bead of the wheel. A 5" off set moves the wheel closer to the trailing arm, or closer to the center of the wheel.
PostPosted: Thu Feb 21, 2013 7:08 pm
Something to think about :idea: wider trailing arms give you more suspension travel and the axles hold up better do to less angle on them. With wider trailing arms you need more back spacing to be able to get around the trails. Also more back spacing makes it easier on the wheel bearings.
Huey
PostPosted: Thu Feb 21, 2013 7:46 pm
Huey wrote:
Something to think about :idea: Longer, wider trailing arms give you more suspension travel and the axles hold up better do to less angle on them. With longer trailing arms you need more back spacing to be able to get around the trails. Also more back spacing makes it easier on the wheel bearings.
Huey
That's close Huey, but not quite. The wider the trailing arm the more travel. The longer the trailing arm the more weight it moves forward. The wider the arm the more offset one would need to maintain a track width and make things easier on the bearings.
The more off set he uses he will need to think about shock clearance.
PostPosted: Thu Feb 21, 2013 8:50 pm
Your right. I meant wider. With my 3X3's I have a lot more room for the shocks to mount.
PostPosted: Thu Feb 21, 2013 9:03 pm
PostPosted: Fri Feb 22, 2013 12:40 am
Ok so....... A wheel that has 2 inch offset will put the tire farther away from trailing arm then a wheel with 4 inch back space rite? Im not retarded I swear lol just dont get why they make it so hard. :?
PostPosted: Fri Feb 22, 2013 12:50 am
It's not hard, your just putting too much thought into it. You have the right idea. :idea:
PostPosted: Fri Feb 22, 2013 7:00 am
Ok cool just as long as I know which way is which lol. Thanks all for the help. As soon as I figure out how to get my pics down to 120 x 120 ill post some. Have a great weekend all. :mrgreen:
