It is currently Sun May 03, 2026 12:17 pm
 Post subject: stroker??
PostPosted: Tue Feb 12, 2013 9:58 pm
I currently have an 1835 and I'm wanting some more power. However I want to stay cheap, so if I were to buy a 74mm flywheel can I stay with my rods and pistons and not machine the block
 Post subject: Re: stroker??
PostPosted: Tue Feb 12, 2013 10:05 pm
I think you mean crank shaft. the answer is yes, you can go up to 76 Millimeter. You will need to shim the jugs/ cylinders out for proper deck height and compression. I ran a 1976cc engine very strong running engine. Check your current end play or get it checked if it is in specs then you will make a good investment with crank, bearings, seals and you may re-ring it depending on condition of the old ones. If you are doing his you may decide to go with a more aggressive cam.
PostPosted: Tue Feb 12, 2013 10:11 pm
Lmao yes I meant crank I have a lightweight flywheel Engle 120 cam I built the motor last winter it runs good and is still nice and tight but I want some more torque I also want to get anther Webber 44 carb to go with the one I bought last spring
PostPosted: Wed Feb 13, 2013 8:50 pm
You may have to do some light clearancing in the block. If your looking for more torque you should look into a smaller cam and stay with the single carb. 44mm carbs are pretty big for an engine of that size.What heads do you currently have?
PostPosted: Wed Feb 13, 2013 8:56 pm
I have jerman 041 heads ported and polished with dual valve springs
