It is currently Mon May 04, 2026 7:09 am
 Post subject: Need manifold heat
PostPosted: Thu Jan 31, 2013 7:42 pm
I have a 1843 single weber carb with an empi manifold, after market exhaust, the tubes that came with the manifold are missing and the headers don't have a place to instal the heat.
I've looked at a few post that take from the # 2 and exit to the collector. what parts do I need? can't seem to find the tubes that go from the intake to exhaust, do I just make my own? as far as the connection to the header do I purchase the block offs the drill a hole?
Thanks
 Post subject: Re: Need manifold heat
PostPosted: Thu Jan 31, 2013 8:48 pm
run a 2" hose from your air cleaner to down under your push rod tubes.
PostPosted: Thu Jan 31, 2013 8:52 pm
Does that work very well? I have a weber style air cleaner without place to connect a hose
PostPosted: Thu Jan 31, 2013 9:10 pm
did you really thinking asking in a different thread would help? :lol: :lol: :lol: :lol: :lol: :lol: :lol:
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=109&jfile=viewtopic.php&f=3&t=14618
just kidding
i have looked around and cant seem to find the tubes either. unless you buy a whole manifold. but the tubes are useless without the ports on the exaust.
i like the idea about running oil through the manifold but not easy without full flow.
i would go with the idea of grip heaters the closer you can get them to the carb the better they will work.
