It is currently Sun May 03, 2026 8:23 pm
PostPosted: Thu Jan 24, 2013 7:06 am
been having problem with bolts backing out on mainly the outter CV's. I'm talking about over time period of just a few hours riding it's been doing this. Not seeing anything noticably out of place to cause it but something obviously is. Anyone had similiar problem?
PostPosted: Thu Jan 24, 2013 7:20 am
Used to have to tighten them every stage on ours, no matter now tight they were they still backed off from the vibration.
Put Nordlock washers under them, never been an issue since.
PostPosted: Thu Jan 24, 2013 8:28 am
When you pack grease in your cv's make sure the holes stay dry and put some blue loctite on the bolts. I guess you could drill them and safety wire them.
PostPosted: Thu Jan 24, 2013 9:04 am
Nice, I'm getting a few of them.
https://www.youtube.com/watch?v=Pc53qDl ... ata_player
PostPosted: Thu Jan 24, 2013 10:14 am
I have lock washers on mine and also after you get them tight, take a pair of vise grips and go back over them you will be amassed how much tighter they will get
PostPosted: Thu Jan 24, 2013 11:35 am
I use a 12 point 3/8" socket and 3/8 breaker bar. No locktite or lock washers used and I have never had one come lose.
PostPosted: Thu Jan 24, 2013 11:37 am
I've never heard of Nord-lock but they are awesome.
PostPosted: Thu Jan 24, 2013 12:31 pm
I've used loctite, VC3, schnorr washers, red loctite with primer, nothing kept them tight. The Nordlocks do though, never worry about them now. Come damn close to rounding the heads out trying to slacken them though :D
PostPosted: Fri Jan 25, 2013 6:25 am
anyone know right off hand how much these nordlocks are? I havent tried loc-tite or anything yet, I usually leave that as a last resort but I'm getting to the point now of putting some red loc-tite on em!!!
PostPosted: Fri Jan 25, 2013 2:57 pm
Are you using the cheapo CV boots with the tin plate flange? If so maybe they are crushing on you allowing the bolts to loosen up.
PostPosted: Fri Jan 25, 2013 7:42 pm
i like those washers i have this problem and have sheered bolts off cause of it
here is one place to get them also on ebay you can buy 25 at a time for 20 or so bucks
http://www.fabory.us/pages/home.html;js ... 172BC0C41A
http://www.clipsandfasteners.com/Nord_Lock_s/210.htm
PostPosted: Sat Jan 26, 2013 10:47 am
If you have alot of grease between the cv and stub axle they will loosen up. Always clean the grease of the outer edges real good before putting them together and this should cure your problem.also like ody said the same goes for the cv boots as well. Chad :mrgreen:
