It is currently Mon May 04, 2026 9:35 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Jan 24, 2013 1:09 am
wow nice work 8) I like the way you've got the gas pedal setup, keep up the good work!
PostPosted: Thu Jan 24, 2013 6:56 am
I think to myself back on th gas pedal how can I make this 10 x harder than it needs to be and let's do it...there should have been many better ways to go bout it but oh we'll...I should have hung the pedal.
PostPosted: Fri Jan 25, 2013 3:27 pm
Well got some more work done. I got side tracked and built a cart for the shop...it will end up being my tubing bender cart so everything is contained. Till then I will be able to use it on set for work! To keep my tools locked up since people have sticky fingers. Below is the progress.
Winch control box, fuel pump, driver and passenger mirrors, rear view mirror.
PostPosted: Tue Feb 05, 2013 11:30 am
You have a really good looking rail yield goin on there !! I'm also building the same chassis for myself. I'm a big guy and I made a dash similar to you'res and it beat my legs to death off road. Might want to pad the bottom above of it above you're legs . Just my opinion. Looking great so far !! What kind of mirrors did you use ? I need some myself and I like the ones you have !
