It is currently Tue May 05, 2026 12:55 am
 Post subject: Torsion eliminators
PostPosted: Sat Jan 05, 2013 6:52 pm
To my understanding madmike isn't making these any more so does anyone know where I can get a beefed up set?
 Post subject: Re: Torsion eliminators
PostPosted: Sat Jan 05, 2013 9:09 pm
Call Tim at Southern Buggies. He will either have them or know where you can get some.
PostPosted: Thu Jan 10, 2013 11:14 am
I was pointed in the direction of drews but I don't think they can get the double sheered... Is there any more options out there?
PostPosted: Thu Jan 10, 2013 11:30 am
If you can weld just buy the single shear and take a short chunk of tube and cut the side out so the heim can pivot. Then weld it to the torsion plate and then cap the tube end and drill a hole in it. Double shear.
I'm a big proponent of double shear but I have never read of anyone having a failure on the single shear plates available everywhere.
PostPosted: Thu Jan 10, 2013 12:09 pm
i bought the dres ones first and bent them all to hell....went with the appletree this time...not double shear but they are nice and thick and a good foundation to start with
PostPosted: Thu Jan 10, 2013 12:26 pm
Really, is it that simple? :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Thu Jan 10, 2013 2:14 pm
Ive never read of any problem with the single shear "plate" because it doesn't break, the heim joint does lol
"IT IS WHAT IT IS"
PostPosted: Thu Jan 10, 2013 2:50 pm
The plate doesn't break but it will bend. When the bolt boss bends it makes it so the axle needs to be shorter. The arm WILL move towards the inside of the car the Axle WILL hit both the drive flange and the stub axle causing big problems.
If you know someone that is breaking heims, tell them to quit buying the cheap ones. They aren't saving any money when you need to keep replacing them. I ran the same heims on my car for years, I wore them out, never broke one.
PostPosted: Thu Jan 10, 2013 4:17 pm
im running 3/4 x 3/4 heims....would like to have a good extra set? where do i get the GOOD ones?
PostPosted: Thu Jan 10, 2013 4:33 pm
Make sure you get chromoly or they will look like thisImage
PostPosted: Thu Jan 10, 2013 5:42 pm
http://www.speedwaymotors.com/Chromoly- ... 31747.html
PostPosted: Thu Jan 10, 2013 6:29 pm
MadMike wrote:
http://www.speedwaymotors.com/Chromoly-Heim-Rod-End-3-4-16-RH-Male,31747.html
U could b a good buddy an scrape up enough scrap to build a set an ill order the hiems! Lol
PostPosted: Fri Jan 11, 2013 12:53 pm
Nice try, do you know what a good buddy is?
You will have to wait just like everyone else for me to finish my car. Besides I don't have any more material to make them now.
PostPosted: Fri Jan 11, 2013 1:24 pm
It was worth a shot.. I guess I'm gonna go with the eagle performance ones.. There not double shear but look pretty week built.
PostPosted: Sat Jan 12, 2013 7:39 pm
pacific customs moore parts appletreee
or get out the tools?
i made the double shear bolt retainer parts and sourced the other from mail order web place.
PostPosted: Sat Jan 12, 2013 10:01 pm
That looks pretty good.. Have u had any trouble with them?
PostPosted: Sat Jan 12, 2013 11:31 pm
No, i just did the double shear bolt stop thing for winter upgrade and havent run em yet but the standard mount didnt give me anny trouble?
cron
