It is currently Mon May 04, 2026 2:44 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: 2332 build questions
PostPosted: Sun Jan 06, 2013 2:40 pm
I am planning a 2332 build. I have a set of 042 (40x35.5) non ported heads,and a set of 45 dells to start with. I do not know what cam to run ? Also looking at 12:1 comp. any build ideas?
Buggy specs:
31x15.50 tires
3rib trans
Not sure on weight 95" two seat frame
 Post subject: Re: 2332 build questions
PostPosted: Sun Jan 06, 2013 10:43 pm
Just saw a 2332 on www.glamisdunes.com for $3500. Probably not a terrible deal considering what it would cost to build it completely. May check the samba, race dezert and other sites for deals before building one.
PostPosted: Mon Jan 07, 2013 2:02 am
That's a lot of compression . I got a c45 cam from scat and like it in my 2276. Not to be mean but I think u will gernade that 3 rib unless its fully weddle. Just my opinion. Depends on how mean you are to it
PostPosted: Mon Jan 07, 2013 6:06 am
I have a 6 rib for when that happen :twisted: s
PostPosted: Mon Jan 07, 2013 6:44 am
Good ur gonna need it . Lol I wouldn't run that much compression though u don't it with 2332.
PostPosted: Mon Jan 07, 2013 9:16 am
I have a fk87 cam ,1.4 rockers , 9.5:1 compression and 5.5 H beam rods and love it. Some say the compression is a little low, but it runs good with a holley 500 cfm 2 barrel carb.
PostPosted: Mon Jan 07, 2013 9:20 am
I forgot to add cb 044 heads. Good luck with the build.
PostPosted: Mon Jan 07, 2013 9:28 am
Where do you get an intake for that set up
PostPosted: Mon Jan 07, 2013 9:40 am
I made it out of a progressive carb intake. Got the idea from dave hix. He has pictures of what he made on here somewhere.
PostPosted: Mon Jan 07, 2013 1:55 pm
I got the idea from a buddy . we used the bends from old trampoline frame :mrgreen: and made the rest. definitly a good way to go for the $$$.
PostPosted: Mon Jan 07, 2013 2:04 pm
How does that carb handle sidehills/hill climbing. Any flooding issues
PostPosted: Mon Jan 07, 2013 2:09 pm
it did good . took a little playing with to get it straitened out.
PostPosted: Mon Jan 07, 2013 3:19 pm
I bought a reman one off of ebay for just under $200 and put size 60 jets in it and it runs great all around.
PostPosted: Mon Jan 07, 2013 4:01 pm
fortydegnorth wrote:
Just saw a 2332 on http://www.glamisdunes.com for $3500. Probably not a terrible deal considering what it would cost to build it completely. May check the samba, race dezert and other sites for deals before building one.
Or woodsbuggy.com........... :mrgreen:
http://www.woodsbuggy.com/index.php?opt ... &sk=t&sd=a
PostPosted: Mon Jan 07, 2013 4:41 pm
Or that^^^ :oops:
Well said Gary. And for the money I don't know if you can even come close to building that same engine yourself.
PostPosted: Mon Jan 07, 2013 8:33 pm
Does the cam need clearanced when running a 84mm stroke dpr Chevy journal and cb 5.5 rods
PostPosted: Mon Jan 07, 2013 10:17 pm
yep, and in my opinion for only $20 more i would go ahead and get a 86mm stroke crank unless you already have the 84
PostPosted: Tue Jan 08, 2013 7:20 am
Not a bad idea but will my heads support that size of motor and still run good?
PostPosted: Tue Jan 08, 2013 7:26 pm
imo the valves are a little small for even a 2332, do they have any port work?
regardless, heads are an easy upgrade down the road without having to split the case and can be done with the engine still on the buggy
PostPosted: Tue Jan 08, 2013 8:17 pm
They are chinese 042 they look to have larger ports cast in. They have dual springs with chromeoly retainers and stainless valves i got from a local source. I can post pics when i get them back from being cut. I just want to make sure i dont pick the wrong cam that would not work with bigger heads . i am thinking about a fk43 and 1.4 rockers
PostPosted: Tue Jan 08, 2013 8:32 pm
That would be a good cam but I would still port the heads if at all possible. 12:1 is WAY too high for compression. 10:1 would be good but you will still need to mix race gas and premium to control detonation.
PostPosted: Tue Jan 08, 2013 9:59 pm
That would suck to try and mix gas every time you filled up. If your shooting for max HP for your combo go 12:1 if not 9-9.5:1 on pump gas :twisted: ... 12:1 would be worth 10-15 more hp prob around 140 hp @ 12:1 with dual carbs
Travis
PostPosted: Tue Jan 08, 2013 10:22 pm
That's what I was thinking I already run 100LL in my 1835(10:1) Is there any major downsides to running high comp.
PostPosted: Wed Jan 09, 2013 8:29 pm
You need to match the compression to the cam your going to use.If you use the FK-43 I would recommend no more than 10:1. To run really high compression you need a long duration cam to bleed off some cylinder pressure.100LL aviation gas won't support 12:1 compression and actually isn't intended for use as a performance fuel. It is really intended for low rpm engines. I feel you could get away with using that fuel with 10:1 but I would add a little marvel mystery oil to it because it does'nt have any good top end lubricants in it.The gains from 10:1 up to 12:1 are only 4.5%. Higher compression leads to higher operating temps and accelerated wear.If it were a race engine I would say go for it,but in a woodsbuggy its senseless in my opinion.
PostPosted: Wed Jan 09, 2013 9:07 pm
X2 The fk43 works good for me with 10.3 to 1 and dual 44 carbs with ported S/E heads and 100 octane gas. They will not sell AV gas around here with out tail numbers and name.
