It is currently Mon May 04, 2026 7:00 am
 Post subject: warrior beam question
PostPosted: Sat Dec 22, 2012 6:27 pm
what bushings do i need i went and bought some for linkpin but they wont go in far at all like they are to big
PostPosted: Sat Dec 22, 2012 7:08 pm
I had the same problem. I sanded mine down until it would fit.
I think I can, I think I can....
PostPosted: Sat Dec 22, 2012 9:16 pm
Same here took the bushing and turned them down to fit
PostPosted: Sat Dec 22, 2012 10:19 pm
I have never figured out the right ones. I sanded mine down as well.
PostPosted: Sat Dec 22, 2012 10:44 pm
Southern Buggys / WB Sponsor
Tell you a little trick if your using the urethane bushings...Please put saftey glasses on and buy a hard wire brush for a grinder. Put the bushing on the trailing arm and take a layer off all the way around with horizontal motions. Check fitment then sand again until the arm will pass through with little effort. Be sure to lubricate the bushings inside and out real good, I like to use anti-seize for the lubricant instead of grease. Arms should rotate with out binding if properly done but should not have any up,down,left,right mothion.
PostPosted: Sat Dec 22, 2012 10:53 pm
The red ones I bought once would fit in the beam but the arms would not fit in the bushings after being put in the beam . I took a 1 1/2 hole saw and ran it threw untill a snug fit . Worked real good .
PostPosted: Sat Dec 22, 2012 10:55 pm
the red bushing for a link pin are for a stock beam.. you have to order the bushing FOR a warrior beam, $4.95 a piece at dans performance
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
