It is currently Tue May 05, 2026 1:58 am
 Post subject: 3 rib the cheap way?
PostPosted: Thu Sep 13, 2012 11:12 pm
im trying to put a 3 rib in my buggy and skim on the details for now. couple of questions. stock 70 bug everything right now. can i just buy type 2 cvs and just replace my inboard cvs? if not whats the cheapest alternative? will this work for the clutch http://www.speedwaymotors.com/Speedway-Hydraulic-Clutch-Pedal-Kit-Floor-Mount,57507.html?utm_medium=CSE&utm_source=CSEGoogle&utm_campaign=CSEGOOGLE&CAWELAID=1413453200 or is there a cheaper way? right now i have stock autostick pedals no clutch pedal. what should I know about flywheels and pressure plates? can I just go to autozone and get a complete setup for a bus?
 Post subject: Re: 3 rib the cheap way?
PostPosted: Fri Sep 14, 2012 2:13 am
that should work for a hydraulic clutch pedal setup as long as the slave cylinder is long enough
a type 1 clutch kit is what you need as far as the disk and pressure plate but you need to know if the tranny uses the early or late style thowout bearings
and yes just change the inboard cv's but you will need shorter axles because the bus trans is wider than a car trans
PostPosted: Fri Sep 14, 2012 8:06 am
Do not forget the Front and Rear Mounts.. The nose cone & bell housing have different bolt patterns.
You will also need a new starter. The stock type 1 starter will not work on a 3rib trans.
PostPosted: Fri Sep 14, 2012 10:27 pm
is 350 a good deal on a trans i dont have to drive far for?
PostPosted: Sat Sep 15, 2012 1:35 am
not bad if its a good tranny! id pay it if i needed it!ive seen people pay more :wink:
PostPosted: Sat Sep 15, 2012 8:00 am
A stock VW starter will work on a 3 rib. You should not have to change the starter.
PostPosted: Sun Dec 16, 2012 10:42 pm
Ok, putting a 3 rib in the place of a car trans what size axels are needed and where can you get a set for a decent price?
PostPosted: Sun Dec 16, 2012 11:49 pm
If you are running stock size rear arms, then Porsche 924/944 from 84 or older will bolt right in, can usually find them on ebay or junkyard.
Good Luck
Kenric
PostPosted: Mon Dec 17, 2012 12:18 am
someone show me vw thing axles and stub axles would work but i ended going with these
http://www.appletreeauto.com/product.php?productid=18672&cat=17&page=1
http://www.appletreeauto.com/product.php?productid=17977&cat=149&page=1
PostPosted: Mon Dec 17, 2012 12:25 am
Ok, thanks so whats the actual length you would need?
PostPosted: Mon Dec 17, 2012 12:47 am
PostPosted: Mon Dec 17, 2012 2:40 am
Ok, should've clicked on the links first
PostPosted: Mon Dec 17, 2012 12:16 pm
hpfreak wrote:
i bought the whole 3x3 trailing arm kit for 700 when i done mine! but those stub axles didnt last long :roll: so i went back to the german ones. drews sells them. they take type 1 and add a ring to them and drill for type 2. so in a jam you can use either i think? havent had a problem with them since! i still have my old axles and arms off of mine if anyone is interested :mrgreen:
PostPosted: Mon Dec 17, 2012 12:58 pm
Ive got a set of aftermarket axles for your set up 80 shipped
"IT IS WHAT IT IS"
PostPosted: Wed Jan 02, 2013 9:33 pm
You could just change your inboard cv's with bus units it works well
PostPosted: Wed Jan 02, 2013 9:48 pm
i read an articule on that and heard it works well but I cringed at the thought of a 3 rib torquing on some type ones espescially when my main goal is reliability. but none the less thats neither here nor there ive already completed this task and the buggys running again. I ended up getting stub axles and empi axles. appreciate the help though.
PostPosted: Wed Jan 02, 2013 11:33 pm
the car axles will work on the bus trans that you already had just have to change the joint on the trans end and run a car joint on the bottom end they work good unless you have a good strong moter then you may have to drill them for the bus joint to work if you go to a 2 by 3 arm then you need to get some 18 and 3/4 axles from a bus
