It is currently Mon May 04, 2026 2:35 pm
 Post subject: Ummm Big problem??
PostPosted: Sun Dec 16, 2012 7:57 pm
So ive been clearancing my case for the stroker build, crank is all assembled everything clears nicely. Set the cam in to make sure everything is good there, Well the Thrust bearing ( Bearing closest to gear) Doesnt fit onto the cam? Im very confused by this...lol I went double thrust bearings, Is this not compatible with an fk8 or something? The bearing is simply to wide to fit between things..
"IT IS WHAT IT IS"
 Post subject: Re: Ummm Big problem??
PostPosted: Sun Dec 16, 2012 8:01 pm
Just use a hammer. You can fix everything with a hammer. :twisted: :twisted: :shock: :twisted: :twisted:
PostPosted: Sun Dec 16, 2012 8:10 pm
Lmao :lol: :lol: Crossed my mind!! Not! :wink: I keep thinking Im just young, dumb and over looking something...But its very clear it doesnt fit lol
"IT IS WHAT IT IS"
PostPosted: Sun Dec 16, 2012 8:19 pm
Ha....got it! there was a itty bitty imperfection on the cam stopping it filed that just a hair and..what do ya know lol It popped right in with a bit more pressure, Suppose I try to be too gentle with things.
"IT IS WHAT IT IS"
PostPosted: Sun Dec 16, 2012 8:24 pm
did you try to fit the cam bearing onto the cam out of the motor, what you should do is take a set of calipers and measure the overall width of the cam bearing and the cam journal, and see whats different, and compare some of the measurements to your old cam and bearings
PostPosted: Sun Dec 16, 2012 8:26 pm
dam your fast :shock:
PostPosted: Sun Dec 16, 2012 8:32 pm
haha, Yea I measured everything with calipers the gap was 1.10, the bearing was 1.10 thats when i found the tiny little imperfection.
"IT IS WHAT IT IS"
PostPosted: Sun Dec 16, 2012 8:51 pm
I dont have any old parts to compare to buddy, The 1915 is staying completely together for a back up :D
"IT IS WHAT IT IS"
PostPosted: Sun Dec 16, 2012 10:38 pm
You will need to set the end play on the cam. You have to LIGHTLY sand the bearings on a nice flat surface to get the desired clearance. Only do one side of the bearings and make sure you do the same side for both halves. I like about .002"-.003" end play.
PostPosted: Mon Dec 17, 2012 6:40 am
I was wondering about that , because theres no movement at all . It spins freely but no clearance.
"IT IS WHAT IT IS"
