It is currently Mon May 04, 2026 2:05 am
PostPosted: Tue Dec 04, 2012 9:13 pm
Well still on the fence on useing my stock AS41 case that has some corrosion or buy a good AS41case or buy a aluminum case the a 84mm stroker will fit in to . I'm looking for some opionions on what way to go.
PostPosted: Tue Dec 04, 2012 9:36 pm
Im using a stock Mexico As41 for my stroker build, But if i had the funds i would be going aluminum super case. So if $$$$ allows do it!
"IT IS WHAT IT IS"
PostPosted: Tue Dec 04, 2012 9:40 pm
If your going stroker and can afford it then no brainer super case all the way. no clearancing just bolt together and ready to figure compression. only way to go.
PostPosted: Tue Dec 04, 2012 10:09 pm
I'm kind of thinking that it would be added insurance against a case failure too
PostPosted: Tue Dec 04, 2012 10:29 pm
http://www.thesamba.com/vw/classifieds/ ... id=1352057
PostPosted: Tue Dec 04, 2012 11:14 pm
If dollars are not an issue go super case. Used cases often have thrust issues. You also can order it exactly the way you want it, clearanced, bored, full flowed. I just don't see the downside. I certainly wouldn't buy a used case from across the country it could be junk and once you paid it is yours. I think a super case is like $800.00 only a couple hundred more than used.
The super cases are much stronger and don't have thrust issues like the OEM cases. The best VW OEM cases were fuel injected cases with no provisions for a mechanical fuel pump.
Super case may be expensive but as a wise man once say it is better to cry once and pay the price than to have to pay for it twice.
PostPosted: Tue Dec 04, 2012 11:21 pm
The best VW OEM cases were fuel injected cases with no provisions for a mechanical fuel pump They are as21 Go aluminum tho you will be happy you did
PostPosted: Wed Dec 05, 2012 12:32 am
I've seen some bad line bore jobs that just robbed power.
PostPosted: Wed Dec 05, 2012 4:45 am
the aluminum case is the better case once its "fixed", some of the new mag cases need a little attention also
PostPosted: Wed Dec 05, 2012 6:31 am
What do you mean Chris? What needs fixed?
PostPosted: Wed Dec 05, 2012 2:18 pm
on the aluminum case the most common problem seems to be the the oil holes dont line up very well in the main journals and the oil pump to block ports tend to be off some also, and they also tend to need some "cleaning up" on the inside surface (sharp edges), however i have read on the samba where a couple of folks had to have a linebore done due to the journals not being completely in line or being undersized and putting to much "crush" on the bearings, these last 2 seem to be somewhat isolated problems though
PostPosted: Wed Dec 05, 2012 2:57 pm
I think your chances of finding a perfect OEM fuel injected block are a bit like finding hens teeth. I have built a couple of engines in my day and the last was a 2.0 Porsche 914 the benefit to the type 4 is the all aluminum cases.
I have spent big money on type 4 $h_t and it just isn't reliable like the type 1. You could always join the dark side an install an echotec for about the price of a case, Just a suggestion. :twisted: :twisted:
PostPosted: Wed Dec 05, 2012 6:29 pm
Is there any brand off aluminum case that is better????
PostPosted: Wed Dec 05, 2012 8:19 pm
They all come out of the same factory.
