It is currently Tue May 05, 2026 2:03 am
Post new topic Reply to topic  [ 160 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu Sep 20, 2012 8:29 am
I have to check my parts pile and see if I have some bus cv's floating around. I used to somewhere. Looks good.
PostPosted: Thu Sep 20, 2012 11:38 pm
Remanufactured my autostick pedals today. Had to make room for a clutch pedal. Basically just cut the brake pedal in half and moved the arms closer together making a smaller pedal.
PostPosted: Thu Sep 20, 2012 11:43 pm
PostPosted: Sat Sep 22, 2012 10:27 pm
Got my clutch pedal. Need some pics of how your mounting your slave cylinder. Dont think the stock bowden tube bracket is going to work.
PostPosted: Mon Sep 24, 2012 8:24 pm
Hey man post the completed photo's if you have them. You do nice work
PostPosted: Mon Sep 24, 2012 8:40 pm
ive very quickly learned that a buggy is never "completed". once I thought it was close I took a testdrive and that put me back about 20 steps. now beating myself over the head for not puting a 3 rib in it in the first place and now the buggys all tore back apart putting a 3 rib in. but thanks for pointing out that I dont have any pics of the complete buggy. I dont have enough room in my garage to stand back and take a complete pic. maybe ill just make a walkaround video.
PostPosted: Mon Sep 24, 2012 10:03 pm
tranny is mounted now. made a bracket for my clutch slave. now im looking at shift linkage issues. I thought I was going to be ok because my box was too high for the bug tranny. boy how i was wrong they really put the 002 hockey stick up there. it might have been ok except my shift rod hits the front brace for the rear seats before its high enough. I also think my shift rod is too short to use the adapters they sell. Im going to try to weld 2 late bug shift couplers together one atop the other, bottom one hooked to the shift rod and top one hooked to the hockey stick. has anyone tried this? I cant think of any reason why this wont work but what can go wrong will go wrong.
PostPosted: Mon Sep 24, 2012 10:31 pm
if you got a hydraulic clutch, you need to just put in a new peddle assembly too and be done with it! and i got some short axles ,have to check their size!probably all the other stuff too!
PostPosted: Mon Sep 24, 2012 10:43 pm
still need 15 5/8 axles, 2 bus cv's, flywheel (need 8 dowel to guide me drilling crank or a 8 dowel jig), clutch, pressure plate and gland nut bearing. if you have any of this id be glad to drive to cinti and trade some cash for them.
PostPosted: Mon Sep 24, 2012 11:02 pm
i'll look thru my stuff tomorrow, and let you know what i got! alot of stuff i keep just in case :shock:
PostPosted: Thu Sep 27, 2012 12:31 am
making some progress on the tranny. got everything mounted and tightened down. ended up bending my shift rod to make it work, not to bad just kinda bowed the whole thing a little. clutch slave mounted just gotta run the line.would i be ok to run soft nickel line all the wat to the slave cylinder or do i need to hose it a little way? any auto parts store part numbers for a hose? still trying to find some cheap axles and a flywheel. appletree has a lightened 8 pin flywheel for 80 bucks is this a deal?
PostPosted: Thu Sep 27, 2012 7:11 am
You'll need a hose on the slave cylinder end since it moves when the clutch is actuated. As far as hose I guess that depends on what size hard line you run and what fittings. Not sure on the flywheel. The lighter it is the less rotating mass you'll have. A heavy flywheel will give you more of a "torque" feel and get you rolling easier. Of course it'll rev quicker lightened. Maybe ask that question in "Air Cooled" section.
PostPosted: Thu Sep 27, 2012 10:05 pm
If you need the the axles and CV's and stub axles to put a bus transmission in stock length type 1 trailing arms give me a shout, I can hook you up with all German parts for the conversion.
Good Luck
Kenric
gouldvw@gmail.com
PostPosted: Mon Oct 01, 2012 6:18 pm
started straightning up the wiring today, got one of my seat harneses mounted, installed the fuse box, bled the clutch, got it to where i could start the motor and tune the carb in. just need axles. got a few "complete" pictures.
PostPosted: Mon Oct 01, 2012 9:08 pm
i like it man. its really comin together for ya it looks great
PostPosted: Mon Oct 01, 2012 9:14 pm
thanks its turning out alright. the rearend is way to narrow but ill take care of that this winter.
PostPosted: Mon Oct 01, 2012 11:00 pm
It looks nice, I think you need a bigger garage
PostPosted: Sat Nov 24, 2012 1:29 am
should have this thing going again soon santas bringing axles and stub stub axles
PostPosted: Sun Dec 02, 2012 7:39 pm
picked up a shifter knob. nothing special just thought id bump my build :lol:
PostPosted: Sun Dec 02, 2012 9:34 pm
Did you get the auto stick fixed or upgrade to a new trans?
PostPosted: Sun Dec 02, 2012 10:14 pm
3 rib is in waiting on axles
PostPosted: Wed Dec 19, 2012 10:36 pm
got another shift knob :D
PostPosted: Thu Dec 20, 2012 5:39 pm
i like it.. looks fun. only thing missing now is 4 drunks piled in it, hammered down and hangin on :lol: :lol:
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Fri Dec 21, 2012 7:55 pm
im sure ill have no problem finding 3 other drunks to ride in it :lol:
PostPosted: Sun Dec 30, 2012 12:45 pm
new axles are clocked, locked and ready to rock :lol: had to get a new battery thanks to my daughter leaving the lights on :roll: batterys are crazy expensive these days. should have some pics up on the snow buggies thread soon enough :twisted:
and i cant forget about my new best friend this winter. 125000 BTUs is major overkill for my garage but i like being able to get it 80 in about 30 seconds then shutting it off :D
cron
