It is currently Sun May 03, 2026 12:36 pm
PostPosted: Sun Nov 25, 2012 12:23 pm
I thought I had a good case untill I cleaned it up the oil filter/drain plug area is corroded in the inside of the flange area how hard are they to weld up or should I get a new case ??? I will try to post up pics tonight
PostPosted: Sun Nov 25, 2012 1:43 pm
Welding magnesium/ aluminum alloy case will weaken it even further. If it is that bad best to invest in a new all aluminum super case. It is expensive but so are all the other parts in an engine build.
Just my opinion though.
PostPosted: Sun Nov 25, 2012 4:16 pm
if you don't have the money to invest, as long as the studs aren't coming out of case, and the gasket will seal around the screen then it will work. I wouldn't invest in any machining like building a stroker or anything. but if it's ready now then build it. it will last a long time as long as you can seal it like I said.
PostPosted: Sun Nov 25, 2012 7:01 pm
rons machine shop in dayton can hook you up on that problem,you can get his number from larrys off road if you cant find it...and if you want to do it yourself,he will prob give you some tips
PostPosted: Sun Nov 25, 2012 7:43 pm
You can make a bolt in flat piece to seal it up put studs on one side and bolts for the other so you can still split the block and fixes it good. Chad :mrgreen:
PostPosted: Sun Nov 25, 2012 10:12 pm
here is some pics
PostPosted: Sun Nov 25, 2012 10:33 pm
It don't look that bad, I have seen alot worse seal up, as long as the studs are solid then your fine. ( but just my opinion)
PostPosted: Mon Nov 26, 2012 12:15 am
Trash. had a case like that and I'm sure the lifter bores look just like that. It is rotten and do not invest in it.The hidden corrossion in the oil passages will disslove and clog your oil journals.
PostPosted: Mon Nov 26, 2012 12:30 am
That ain't that bad. Get the case looked at by someone who knows what to look for. If it checks out,use it.
PostPosted: Mon Nov 26, 2012 10:43 pm
It dosn't look bad any where else but it does need line bored . but I'm planning on taking it to a shop and getting it checked out
PostPosted: Tue Nov 27, 2012 7:31 pm
X2 I had a case that had the same thing going on and ruined everything I had, wasnt oiling correctly. Junk throw it away.
