It is currently Mon May 04, 2026 4:52 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Passat's buggy pics.
PostPosted: Mon Nov 05, 2012 9:19 pm
PostPosted: Mon Nov 05, 2012 9:31 pm
Final drive ratio on this 307:1 combined with the 339:1 passat is a 1041:1 .1st gear is for sliding houses over lol.I only use 2nd and 3rd for hills.My wife loves hp and I'm really glad I have a stretched timing chain.But I guess I'll fix it after my sons new front end is finished.It will do 70 in fifth fast and easy.I wish I had of used an automatic. Can you imagine going thru 4 or 5 gears on a hillclimb!
PostPosted: Mon Nov 05, 2012 10:11 pm
PostPosted: Mon Nov 05, 2012 10:14 pm
Never thought about the diff being upside down for forward drive. Makes sense I guess since it's basically a second final drive. Cool idea. I like this idea and the idea of a v-drive for a boat that runs to a diff like you have or even a 9" straight axle and avoid cv's altogether.
PostPosted: Mon Nov 05, 2012 10:16 pm
The gears are long, not short. I really love the A arms.This buggy has an incredible soft ride.A straight axle would have No ground clearance.I love those home made rims. Cut the center out of an old 16"car tire spare and put in 6 even 1.5x1.5x 1/4" angle.Stub axles, ball joints are from the front of an Isuzu 2 wheel drive truck , but put the lt on the rt and vice versa.
PostPosted: Mon Nov 05, 2012 10:38 pm
awesome..... glad ur sharin the passat.. spread new ideas n creativity... love it all... oneday in the future your ideas will be known n carried to progress more n more through the years to come for buggies.. just like the sideshifts, no one ran one till we did n now theres all kinds of linkages n contraptions made.. keep up the good work n ideas cuz it is goin far
the women r at the top of the hill
PostPosted: Mon Nov 05, 2012 10:42 pm
This is one awesome machine... I especially like the two steering wheels... :shock: :shock: :shock:
PostPosted: Mon Nov 05, 2012 10:53 pm
PostPosted: Mon Nov 05, 2012 10:55 pm
Thanks Austin, thanks mickey.Now yall can see the bus cv.
PostPosted: Mon Nov 05, 2012 11:18 pm
PostPosted: Mon Nov 05, 2012 11:26 pm
good to see you got the pics figured out :mrgreen: and that new A arm your putting on austins looks good if it works well i will gladly let you do it to mine :mrgreen:
PostPosted: Mon Nov 05, 2012 11:30 pm
ImageThanks Jesse. Now you've created a monster. Thanks for showing me how to post.lol
PostPosted: Mon Nov 05, 2012 11:42 pm
Image Lots of ground hiegth.113"wheel base x 80"wide
PostPosted: Tue Nov 06, 2012 1:32 am
wow :shock:
PostPosted: Tue Nov 06, 2012 8:36 am
It you ever. Broke those joints from trans to diff... Would it not beat the hell outta the oil pan???
PostPosted: Tue Nov 06, 2012 9:05 am
When CV's brake, usually it is always the cage, the axle never leaves captivity. So I doubt he'd have a problem.
PostPosted: Tue Nov 06, 2012 9:41 am
I'm loving the 90 degree approach angle the set back axle/differential gives. Too bad there isn't a spool out there to fit the front differential to get away from welding it. I'm a believer in what you are doing and it obviously works well. Please keep the pictures coming!
PostPosted: Tue Nov 06, 2012 9:49 am
the shaft never changes angle .And it has very little angle aswell.
PostPosted: Tue Nov 06, 2012 10:08 am
Ok say the bolts broke
PostPosted: Tue Nov 06, 2012 10:22 am
Little driveshaft loop welded in would solve that problem. I'm guessing that even a catastrophic failure of the engine wouldn't be a bank breaker. An engine like that from a wrecking yard is probably under $500. That's less than a 091 transaxle that can break by putting it in reverse.
PostPosted: Tue Nov 06, 2012 10:31 am
there is a spool. there is a vw following in other states and countries. I've seen photos on websites but a friend of mine is very good at welding them up solid.I tossed some old bolts in my 1st diff and it worked for almost a year, but when it let go it destroyed the bellhousing wall.Passats and jetta's and New beetles share the same trans and the different ratios of diffs and gears are way too much to count either in automatic or manual.Rite now at pull apart there is a Jetta vr5 170 hp motor with an automatic in a 1999 model.Jetta's and new beetles stayed sideways while Passat went to the trans that looks just like a bus but turns backwards in 1999 and up.Some of those NEWER vr6 Passats have close to 300 hp. Who needs gear reduction with that?Put that on a hillclimb. The motor weight ahead of the rear wheels will be just right the steeper it climbs.Put gas , battery and cooler behind rear wheels.Or just go toyota ,honda, nissan.I can get that trans at pull a part for $70 out the door.
A good running motor at a salvage yard cost what 3 EMPI headers in a box would cost.I put a $20 Auto Zone 3" pipe extension on my stock header and boom I had a great sounding motor.If this is a turn around in more buggies,just saying, ...the parts suppliers would sell more seats, seat belts, 3x3 trailing arms,or 38" like mine, brakes, cut brakes, foot pedals, tires, rims, steering,cv's,traditional front ends, radiators n fans, fuel tanks n pumps, airbags and shocks,modified frames, prefabbed c/v adapters, and start customizing to these popular foriegn motors such as simplified wiring harnesses, computors, chips,consoles,etc.It may take many years but it's coming one way or another.
PostPosted: Tue Nov 06, 2012 12:01 pm
The only Time I've ever seen bolts break on a cv is when they run loose. (Ask me how I know)
And then that is just poor maintenance.
PostPosted: Tue Nov 06, 2012 12:54 pm
This buggy is so mean it takes two people to handle it.are you a narcoleptic and when you pass out the passenger takes over.or just when she gets tired of your driving she takes over.definitely different setups. Chad :mrgreen:
PostPosted: Tue Nov 06, 2012 1:07 pm
lol it's more of a drivers ed buggy. My wife wants all the power out of any motor.The same way she rides a horse.Me, I just want to enjoy beer.
