It is currently Mon May 04, 2026 11:18 pm
 Post subject: limited slips
PostPosted: Tue Oct 16, 2012 5:42 pm
What is the best limited slip to put in that will still allow cutting brakes to work? Best-cheapest place to look?
 Post subject: Re: limited slips
PostPosted: Tue Oct 16, 2012 5:43 pm
tranny is a 3 rib bus
PostPosted: Tue Oct 16, 2012 7:00 pm
ARB air locker fully selectable
PostPosted: Tue Oct 16, 2012 8:03 pm
A good used German super diff is the best or a weedle super diff.it's already a limited slip or should be I'd think.if your not running a lot of horsepower your stock diff should work fine with cutters. Chad :mrgreen:
PostPosted: Tue Oct 16, 2012 10:34 pm
Stock & super diffs are open diffs. no lsd or locker
PostPosted: Wed Oct 17, 2012 4:14 am
as stated a superdiff is still an open diff but it does seem to do better than a regular 2 spider diff and a true locker would make a buggy try push in a turn and the light front only make its worse not to mention making turning brakes useless when locked, my suggestion for limited slip would be the peloquin diff but it aint cheap
read this,
http://www.woodsbuggy.com/index.php?opt ... uin#p98069
in the end i doubt a 3 rib will hold up with anything more than a superdiff unless its all weedle inside
