It is currently Mon May 04, 2026 10:55 pm
PostPosted: Wed Dec 26, 2007 7:19 pm
thanxs for all the help and patience
my next question is what should i do for rear suspension
as in coil over or torsion
and 2x3 3x3 3x5
im running a subie 2.2 and plan to hill climb and drive
thanxs
PostPosted: Wed Dec 26, 2007 7:23 pm
When I went to the 2.2 I lost a little ground clearance and gained a little weight. Build your arms as big as you can afford and go with airbags. The bags are lighter, cheaper, and adjustable from the seat. That's my story and I'm sticking to it. 8)
PostPosted: Wed Dec 26, 2007 9:31 pm
3x5 arms with coil overs will give you the best overall performance AND tune ability. Definitely use the 3x5's with the subie motor. If you don't, your front end will not stay down and it will not climb steep hills.
PostPosted: Wed Dec 26, 2007 9:39 pm
what roy said 10-4
PostPosted: Wed Dec 26, 2007 10:15 pm
I'll have to go with Firebug I have coilovers on my buggy now the springs wear out .Plus it's hard to get the right rate you can spend a bunch of money on springs . I'm trying to go air bag now
PostPosted: Wed Dec 26, 2007 10:16 pm
If I can do it , anybody can... 8) even you pocketrocket
PostPosted: Thu Dec 27, 2007 12:56 pm
ok i think im going to go with airbags for now
and 2x3 arms till i have the money to go bigger and go to 930's
so now i guess i need someone to help point me in the right direction for an airbag system.
thanxs for all yals help
PostPosted: Thu Dec 27, 2007 5:11 pm
There are lots of guys on here that run air bags. I am sure you will get plenty of advice.
PostPosted: Thu Dec 27, 2007 8:40 pm
Here are bags and a kit on ebay. It will give you an idea what you need . Seems like I found similar items at JC Whitney and Summitt racing. There are some other online companies as well. The bags you use may depend on the room you have to work with. I used the size next smaller but when I upgrade I may use these.
http://cgi.ebay.com/ebaymotors/Fireston ... enameZWDVW
http://cgi.ebay.com/ebaymotors/Ride-Rit ... enameZWD1V
PostPosted: Thu Dec 27, 2007 9:32 pm
can someone post pics of how to mount them in--thinkin about them for my 4 seater. And how do u set tension on rear torsion(soft--stiff) when u use airbags----thanks
PostPosted: Thu Dec 27, 2007 10:09 pm
PostPosted: Fri Dec 28, 2007 2:37 am
[quote='Firebug']http://forum.woodsbuggy.com/privmsg.php?folder=sentbox&mode=read&p=8833[/quote]
why is my sent box showing up in you post :eek:
PostPosted: Fri Dec 28, 2007 9:35 am
[quote='kendel'][quote='Firebug']http://forum.woodsbuggy.com/privmsg.php?folder=sentbox&mode=read&p=8833[/quote]
why is my sent box showing up in you post :eek:[/quote]
:eek: same here, when i click on it my sent box opens :eek:
hey firebug, are you a hacker... :lol:
Mike
Got Honda?
PostPosted: Fri Dec 28, 2007 10:19 am
[quote='harleyhunter05']can someone post pics of how to mount them in--thinkin about them for my 4 seater. And how do u set tension on rear torsion(soft--stiff) when u use airbags----thanks[/quote]
When you use air bags, you remove the torsion bars and sell them to somebody. The bag itself is now the spring that holds the buggy up.
PostPosted: Fri Dec 28, 2007 10:21 am
I had sent those pics to Kendel and just copied and pasted . Is this causing a problem,,,,I will stop doing it that way. :eek: I went back and got the pic from photobucket this time. :oops:
PostPosted: Fri Dec 28, 2007 10:25 am
Also when I installed I kept the torsion bars,,,just relaxed them,, slid them straight in with no pre stress ,This left in some weight but it gave me a sorta progressive spring rate. In other words the torsion bars aren't doing much until extreme travel then they kick in . I was told this is not necessary and may even be a bad thing to do but I haven't noticed any adverse effects...I may remove them when I upgrade. 8) When installing the bags get some specs on length open and closed and find a spot where the travel of your arm equals that , kinda like mounting shocks. If the torsion is removed you can tack it up, put the buggy up on stands, leave off the tire and it will be lighter and work the arm up and down to make sure there is no binding. Remember to use limiting straps . I also mounted some bump stops. good luck 8)
PostPosted: Sun Dec 30, 2007 3:05 am
I just read that the bags do not require bumpstops,,,cool 8)
PostPosted: Sun Dec 30, 2007 6:14 am
Hill Climber
I couldn't find a better pic but you can see in this pic the plates I used to get rid of torsion bars when I went to coil overs.
Harry S. Truman
PostPosted: Sun Dec 30, 2007 7:09 pm
what rate springs did you end up with :?
PostPosted: Sun Dec 30, 2007 7:44 pm
Skidz,,I would like to see that up close. I need that setup on my buggy. 8)
PostPosted: Sun Dec 30, 2007 10:32 pm
This is how I did mine
PostPosted: Sun Dec 30, 2007 10:33 pm
were did u get a set like that mike
PostPosted: Sun Dec 30, 2007 10:44 pm
All home built.
PostPosted: Sun Dec 30, 2007 10:49 pm
M&M you are good. :eek:
PostPosted: Sun Dec 30, 2007 10:55 pm
Looks like another fine product of M&M Fab and Machine Inc.
