It is currently Sun May 03, 2026 5:31 am
PostPosted: Fri Oct 12, 2012 9:48 pm
I wore out my 35x14.50x15 boggers and had to upgrade to a little taller tire. Only had it out once and blew a 930.
PostPosted: Fri Oct 12, 2012 10:21 pm
That cut looks a lot better! :wink: Need I say more? :mrgreen:
PostPosted: Fri Oct 12, 2012 10:37 pm
Looks good. Did you do a before and after weight? Chad :mrgreen:
PostPosted: Sat Oct 13, 2012 12:16 am
Those look great. I'd much rather lose a 930 than a transmission. :?
PostPosted: Sat Oct 13, 2012 1:36 am
Those Boggers look GREAT. Just curious, what brand of 930 did you toast?
Thanks
Kenric
PostPosted: Sat Oct 13, 2012 11:31 am
No I didn't get a weight on them. They where race preped Lobro cvs but it had water in it and it's the first one I've broke in 3 years.
PostPosted: Sat Oct 13, 2012 2:39 pm
good job cutting them, that is an ugly tire 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Sun Oct 14, 2012 10:20 am
i have the same tires on weld beadlock rims...total weight 95lbs (post cut)
- Sigmund Freud
- Antonio Meloni
PostPosted: Mon Oct 15, 2012 5:17 pm
Was it easier to cut them off rims or on rims I'm about to cut a new set an was jus curious.
PostPosted: Mon Oct 15, 2012 6:14 pm
How's the suspension load now brad ? It looks like it alot highr in the back .... Freaking stuck in the 80s camaro style ! Lol
PostPosted: Mon Oct 15, 2012 6:53 pm
Brad bought these cut, don't let him fool you. That's right Brad, I busted up your game.
PostPosted: Mon Oct 15, 2012 7:49 pm
on the rim, on the buggy.. its hard to hold the tire AND the sawsall
PostPosted: Mon Oct 15, 2012 8:56 pm
i have a groover.
PostPosted: Mon Oct 15, 2012 9:38 pm
Money520 wrote:
i have a groover.
oh.. on the rim, aired up. we've always sawed the lugs off smooth, that way when u hit it with the groover, its more consistent and not wavy.. careful with a groover and keep a check on the depth of the blade, the rubber is thicker where it rolls over to the side wall than in the center of the tread..
PostPosted: Fri Oct 26, 2012 6:59 pm
Where is the best place to buy BOGGERS ?
