It is currently Mon May 04, 2026 12:18 pm
 Post subject: Rev just wondering
PostPosted: Wed Oct 03, 2012 8:03 pm
what would be considered "too high" of an rpm to be reving my vw at. what would be considered hurting it?
 Post subject: Re: Rev just wondering
PostPosted: Wed Oct 03, 2012 8:09 pm
What are some details on your engine?
For my engine, a built up 2276, I run a rev limiter at 6000RPM,
PostPosted: Wed Oct 03, 2012 8:12 pm
Cam, rockers, pushrods, valve springs, etc. etc. all play a role in this. I remember a stock single port motor that Kyle Martin had SCREAMING at 4,000.
PostPosted: Wed Oct 03, 2012 8:48 pm
my redline is at 6000 had to take it to 6500 last saturday night...if you runnin anything close to stock id stay at 5000
PostPosted: Wed Oct 03, 2012 9:25 pm
it will stop its self just keep it on the floor till you get to the top :lol:
PostPosted: Wed Oct 03, 2012 11:25 pm
Great answer Dink, I always use to let it eat, what do you need a tach for? Thats what rev limiters are for.
PostPosted: Thu Oct 04, 2012 11:12 am
I have know idea if it has a rev limiter on it. I if it does I have never hit it. 2350 Webber 44. Not sure about the push rods and what not though. I believe the highest I have gotten it up to was 5000 rpm.
PostPosted: Thu Oct 04, 2012 11:25 am
how did you come up with 2350?
PostPosted: Thu Oct 04, 2012 11:46 am
duneman wrote:
I have know idea if it has a rev limiter on it..
Well does it have an MSD ignition box or not ? If so, which one?
And yea, what's a 2350?
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Thu Oct 04, 2012 1:07 pm
If you do have stroked engine it will not tolerate RPM in excess of 6,000 without serious balancing and blueprinting. If all internals (rod assembly, pistons) are gram-ed out to 1/10 of an gram then higher rev limits are possible. Most rod sets are matched meaning they are within an acceptable range. Piston sets are the same. By weighing them and by shaving/ polishing off material in areas that do not compromise the part until each piece is within a tenth of a gram.The entire rotating assembly can be balanced together following the gram-ing of the rod assemblies and pistons. This level of balancing will produce the greatest potential for a smooth running high revving engine.
PostPosted: Fri Oct 05, 2012 11:48 am
So basically just play it safe and not go over 5k?
PostPosted: Sat Oct 06, 2012 7:24 am
5000 is a good number to keep it at. You are really not gaining much anyhow by taking it to 6000. The lower you keep it the longer between engine overhauls.
PostPosted: Sat Oct 06, 2012 10:58 am
just tape a picture of your kids to your steering wheel as a rev limiter.
PostPosted: Mon Oct 08, 2012 7:34 pm
i had a motor guy tell me if you cant climb it at 5500 rpms you cant climb at 6000. i dont know if its true or not ive been asking myself the same question on where to set the msd box at on mine.
