It is currently Sun May 03, 2026 11:06 am
 Post subject: torsion bushings
PostPosted: Tue Sep 11, 2012 11:39 pm
Is there another type of bushing for the rear torsion bar that doesn't squeak? I've replaced the bushings (red poly) currently I've added a couple of washers for spacers to decrease the pressure, is this ok?
Thanks
 Post subject: Re: torsion bushings
PostPosted: Wed Sep 12, 2012 8:58 am
Nylube works fairly well.
PostPosted: Wed Sep 12, 2012 9:10 am
stock black rubber bushings are the best. hrd to find in good shspe though.
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Sep 12, 2012 3:59 pm
Just load them with anti seize. Haven't had a squeak since.
PostPosted: Wed Sep 12, 2012 7:24 pm
Thanks so much for the input, I'll give the anti-seize a try, I noticed some venders say you should re-size before you install, should they spin freely on the torsion bar and the cap that holds them in? if so what do you do just sand them down?
thanks
PostPosted: Wed Sep 12, 2012 7:46 pm
No you want a snug fit. They should just slip on and I would get rid of the washers. You don't want the bushings or bars and spring plates moving in and out
PostPosted: Wed Sep 12, 2012 7:47 pm
The ones that need honed for proper fit are the front bushings.
PostPosted: Mon Sep 17, 2012 2:20 pm
Thanks for your suggestion on the anti-seize, this worked!
PostPosted: Mon Oct 29, 2012 9:17 am
The yellow saco bushings arent as squeaky.Mckenzies or Kartek has them.
