It is currently Sun May 03, 2026 11:45 pm
 Post subject: positive caster angle?
PostPosted: Sun Jul 08, 2012 8:44 pm
my buggy has extreme positive caster angle, seems to make the buggy suspension very stiff and notchy, was wondering what angle was good for a buggy.
PostPosted: Mon Jul 09, 2012 7:14 pm
I assume this is on the frontend. Linkpin or balljoint?
PostPosted: Tue Jul 10, 2012 11:19 pm
caster is mostly just to make wheels want to go straight. when you make a turn and let go of the wheel and it returns to straight thats caster in action. too much caster would cause stiff steering at speeds. extreme positive camber could cause jerk in the steering wheel over bumps and less turning radius because the wheel is now leaning over more than turning.
PostPosted: Wed Jul 11, 2012 11:16 pm
I assume you mean in the front.What angle do you have the beam mounted at? The more straight up an down you have it, the beam,the more darty an notchy the steering will be.
PostPosted: Mon Jul 16, 2012 1:27 pm
I installed caster shims to straighten in out , fixed suspension and helped steering, thanks
PostPosted: Mon Jul 16, 2012 3:21 pm
what angle is it supposed to be?
although i havent actually leved the frame and put a angle gauge on it most of ones ive looked at appear to to straight up and down at the tubes/beam clamps :?
PostPosted: Mon Jul 16, 2012 6:46 pm
berrien buggy calls for 5 degrees slant back on the tubes.
PostPosted: Sun Jul 22, 2012 7:43 pm
I run between 12-20 degrees.
PostPosted: Sun Sep 02, 2012 9:33 pm
Hey im working on my firs woodsbuggy project, just got done rebuilding the front end, used this for the shim selection http://www.historicvws.abelgratis.com/t ... ins.htm.On the chart bottom right (after 1960) I did a 6.5 mm offset, which now appears to have givin me somewhat of a positive camber angle, should I re-do it so I end up with a negative camber? how do you thing its going to handle with my current setup? i will be running 3 rib tractor tires in the front, stock length warrior front beam, shock relocators and all that. http://i1252.photobucket.com/albums/hh5 ... ntbeam.jpg
