It is currently Sun May 03, 2026 4:02 pm
PostPosted: Sun Jul 01, 2012 2:41 pm
i cant get the bleeder screw out of my calibers they just wont budge and iam afraid iam goin to twist the heads off any easy way to get them out
PostPosted: Sun Jul 01, 2012 2:52 pm
What I have found that works real good is heat the bolt nut or you case bleeder up and take candle wax or crayon and melt it in on threads . It has worked for me better then blaster or other penetration lubes .
Good luck !
PostPosted: Sun Jul 01, 2012 4:01 pm
do you think a propane torch would heat it enough i ant got no torches
PostPosted: Sun Jul 01, 2012 7:38 pm
Yep should work fine on a bleeder . The yellow tanks are map gas and burn much hotter though .
PostPosted: Sun Jul 01, 2012 8:15 pm
one thing that has always worked for me is putting pressure on the wrench and smack the end of the bleeder screw with a hammer. ussually causes enough vibration to jar it loose.
PostPosted: Sun Jul 01, 2012 9:15 pm
ok thx i got it lose
PostPosted: Sun Jul 01, 2012 9:29 pm
What worked ?
PostPosted: Sun Jul 01, 2012 9:41 pm
just put a little man power in it and a few taps and they twisted right out lol thx for the help
