It is currently Mon May 04, 2026 8:16 pm
 Post subject: low budget carb kit?
PostPosted: Tue May 01, 2012 8:59 pm
I need to buy a carb for my buggy. my budget doesnt allow for much. if im going to spend 150 on a stock 34 I figured I could throw in alittle more and upgrade. my choices are a 32/36 weber, a single weber 40 or 44, or a dual solex 34 setup. its going to be a stock 1600 for awhile and probably never more than a mild 1915 (ill save the big hammer build for a two seater). whats going to be my best choice here?
 Post subject: Re: low budget carb kit?
PostPosted: Tue May 01, 2012 9:21 pm
If no one has one on here for ya go on the samba i bought a set of dual.40s linkage.and all like brand new for 300
PostPosted: Tue May 01, 2012 9:35 pm
i got a solex h30 /31pict what it says on the side, with a rebuild kit i think is all there, i ran it on my 1641 for three years, been off for 2 so probably needs rebuilt, i replaced with a single weber 40 and paid 300 for that :shock: but it was brand new from weber. id let you have this solex real cheap if you were interested
PostPosted: Tue May 01, 2012 9:43 pm
as far as I know a 31 will not fit on a 34 intake. plus im not to hip on buying used carbs ive been burned to many times. id rather have peace of mind of a new carb. how do you like the single 40?
PostPosted: Sun Jun 03, 2012 9:27 pm
I would go with a single 40 weber or 44 it will work on the 1600 and the 1915 just fine.
Travis
PostPosted: Mon Jun 11, 2012 9:44 pm
i made up my mind im going with a single idf. just a couple more questions. being the same price should i go ahead and get a 44 or will these really kill my motor while still a 1600? why should i pay almot 200 more for a weber vs an empi? last but not least anyone know where i can get one of these kits around columbus?
PostPosted: Tue Jun 12, 2012 5:22 pm
Ok i ended up just buying a solex 34 just to get this thing going. I found a brand new one right down the street from my work for $145. anyone in or around columbus should look up german autowerks, great guy reasonable prices, they have enough machinery to line bore and rebuild heads. just went in to get a carburetor and ended up shootin the shit with the guy for about an hour.
