It is currently Tue May 05, 2026 12:49 am
 Post subject: Trans seal
PostPosted: Thu May 17, 2012 6:05 pm
What would a guy have to go through to replace the seal under this.
 Post subject: Re: Trans seal
PostPosted: Thu May 17, 2012 7:32 pm
If im thinking correctly, that seal in the cup pops out, theres a C clip behind it. Flange slides off and ya pop the seal your talking about out and pop the new one in. fairly simple. never replaced one myself. But pretty sure thats how it works.
"IT IS WHAT IT IS"
PostPosted: Thu May 17, 2012 8:53 pm
thats it ive done a few that way, very easy.
PostPosted: Thu May 17, 2012 9:46 pm
you know where i can order the new seal? does Dans Performance sell em?
PostPosted: Fri May 18, 2012 2:15 am
i would think Dans would have them. If you call Dan's, tell Dan Emery that you are from Woodsbuggy.com.
He is a really nice guy and very knowledgable. His son actually races buggy's in CA.
PostPosted: Fri May 18, 2012 3:22 am
When u get the flange off look at the flange where the splines are and see if hole is in center of the flange. I had one I couldn't get to stop leaking and found that hole off center. It was so far off the seal didnt hit all the way around the seal surface.Called rancho and they replaced it for free, come to find out it was a empi part number. Wouldn't you know it.
cron
