It is currently Mon May 04, 2026 3:04 am
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri May 04, 2012 8:15 pm
No lash caps or spacers... will need to order some... I see that both come in dif. sizes so I will wait till I get the rockers and once I start with the geometry I will order some...
seemed like a good deal...
PostPosted: Sat May 05, 2012 10:31 am
You will need them to even get started with your geometry. Just order what scat sells with them and get an assortment pack of rocker stand shims.
PostPosted: Sat May 05, 2012 10:56 am
I will get the caps from CB, as I know they will be a good set for heads they sell... The rocker shims come in 15, 30, 60 should I get all 3? I don’t see an assorted set. I also need to order push rod tubes... going to get the Jaycee ones... they seem to be good for ratio rockers and no leaking.
I have the push rod tool... and rockers are on the way... I also have a set of Scat hardened one piece shafts... if I need shaft spacers I will just take them off those (to get valve positioning).
anything else?
PostPosted: Sun May 06, 2012 12:41 am
Check with Vee-Dub parts Unlimited. They will have the assortment and the lash caps. the shafts on your new rockers are bigger so you can't use the shims off you old shafts.
PostPosted: Sun May 06, 2012 9:26 pm
OK man... I just orders the scat rocker arm spacers, and the assorted rocker stand spacers... so I hope that goes well... Also orders the Jaycee pushrod tubes and lash caps from cb performance... along with the better rocker arm studs... picked out a new 36 horse doghouse fan shroud too... now all I need to get my motor back together is an alternator and a fan... last on my list.
once I get my parts I will start up arocker geomitry thread... I hope this goes well...
can I cut the rods... or is this a measure and send out to cut deal?
thanks for everyones help...
