It is currently Tue May 05, 2026 2:01 am
PostPosted: Sun Apr 22, 2012 6:36 pm
busted my last one today need a couple so i can make it to ohio any one have some they will come off of let me know how much
PostPosted: Sun Apr 22, 2012 7:42 pm
Jesse if your busting axles like that you have to have a binding problem some where. Ive been riding for 15 years and never broke an axle. Ive seen one guy that broke a few and come to find out his arm was bent just a little and caused it to bind the axle till it broke.
PostPosted: Sun Apr 22, 2012 9:11 pm
well it happened when i tried to take off in the middle of the hill either them axles i had was old and at their end r i have a problem im gona look into it more befor we go
PostPosted: Sun Apr 22, 2012 10:18 pm
Ive had the same axles in my two seater for 7 years. The only thing ive ever heard was that if you take them out you need to put them back on the same side rotating the same direction.
PostPosted: Tue Apr 24, 2012 12:56 am
hey kevin would to much angle break a axle or would the cv be the problem if i had to much angle to the dangle
PostPosted: Fri Apr 27, 2012 2:40 pm
having no luck finding any :evil:
PostPosted: Sat Apr 28, 2012 11:38 pm
hey jesse i may have some laying around the yard how long are they i will check tomorrow
PostPosted: Sat Apr 28, 2012 11:42 pm
ok cool they are 19 1/4 give me a call if you find some
PostPosted: Sun Apr 29, 2012 8:02 am
I would take a close look at the torsion and make sure its not bent. If its not then pull the trailing arms off and check all the bushings in the torsion and the arms. You will prolly find your problem there.
cron
