It is currently Sun May 03, 2026 6:21 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
 Post subject: Dual 40 IDF's
PostPosted: Tue Apr 17, 2012 2:23 pm
How can i get my idle down? Seems a bit high with the new heads etc, But im out of adjustment, maybe im just having a brain fart here lol
"IT IS WHAT IT IS"
 Post subject: Re: Dual 40 IDF's
PostPosted: Tue Apr 17, 2012 3:19 pm
Check for air leaks maybe....
PostPosted: Tue Apr 17, 2012 3:21 pm
No leaks, issue has always been there of running out of adjustment, and have always wanted a little lower idle Just didnt idle quite as high as it does now .
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 3:49 pm
What idle jet are you running and with what motor?
PostPosted: Tue Apr 17, 2012 4:27 pm
50 idles dont see how that would actually effect my rpms at idle much though.
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 4:29 pm
Note- everything runs great. There are no jetting issues, Simply trying to drop my idle speed down lower.
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 7:31 pm
Do you have any slack in throttle cable?
PostPosted: Tue Apr 17, 2012 7:54 pm
Yea theres slack. the butterflies/arms cant go any further closed. when u back the idle adjustment screws all the way out, theres still a gap there. But thats all the further things move. Chad said bigger idle jets, I bumped them to 55 and it didnt change anything. I cant see changing them anyway since im runnin on the rich side of things anyways and it runs good. definitly cant see going to 60's on a 1915 to get the idle right? seems crazy and Im just confused as hell by it lol
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 8:29 pm
I am running a 1915 as well with 55 idle jets, 130 mains, 200 air, and F11 emulsion and mine idles great so there my thoughts are that there is something else wrong causing this.
PostPosted: Tue Apr 17, 2012 8:36 pm
u have single or duals?
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 8:46 pm
130 seems low This is my jetting before the 044 heads i just put on- 50 idles, 150 mains, 200 or 210 i believe. also run f11's Every runs flawless. and its not an extremely high idle, just slightly higher than i want.
"IT IS WHAT IT IS"
Have you checked the air bleed screws to see if they have been messed with? These are the ones with jam nuts on them. They should be bottomed out.
PostPosted: Tue Apr 17, 2012 8:47 pm
Mind you this is NOT a new issue. Just slightly enhanced with the new parts. :D im sooo confused
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 8:52 pm
Yep. Turned them in when i put the carbs on last year. I'll double check tomorrow, but not seeing that being the problem. lol
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 8:56 pm
Do your butterflies have holes drilled in them?
PostPosted: Tue Apr 17, 2012 8:58 pm
nope, and visually cant see any gap around them. To rule out twisted shafts.
"IT IS WHAT IT IS"
PostPosted: Tue Apr 17, 2012 9:42 pm
if all these things r correct like u say then it shouldnt even idle maybe put corks in the venturies that might bring it down lol
PostPosted: Tue Apr 17, 2012 10:25 pm
Mine are dual 40's and it runs great.
PostPosted: Tue Apr 17, 2012 10:43 pm
lol Ill try that tomorrow!! :lol: :lol: Idk makin no sense. Ima do some double and triple checking on things tomorrow. Ive talked on the phone to numerous people, even went back out to the garage and checked off a list of things while on the phone with kevin. lol everything checks out . Nothing else, it runs great and screams maybe just deal with the slightly high idle. Its not crazy high, just a tad much for my liking. If i find an answer tomorrow ill be sure to let everyone know lol
"IT IS WHAT IT IS"
PostPosted: Wed Apr 18, 2012 12:10 pm
Its just those 44's wanting to play! :mrgreen:
PostPosted: Wed Apr 18, 2012 12:29 pm
check if your fuel enrichment pistons are stuck or gone. they are the 2 little holes with brass lock washer looking things holding them in when you have the top off looking at the float bowl.
PostPosted: Wed Apr 18, 2012 12:36 pm
Thats something I havent heard yet, thanks racebugg Ill check it out.
"IT IS WHAT IT IS"
PostPosted: Wed Apr 18, 2012 4:04 pm
Well, took a minute away from working on other things to check the air bleed screws, they were screwed in. so check that off for sure.
"IT IS WHAT IT IS"
PostPosted: Wed Apr 18, 2012 4:57 pm
Your absolutly sure you do not have an air leak? Sprayed evrywhere with ether? Also what is your timing set at?
PostPosted: Wed Apr 18, 2012 6:06 pm
positive, on air leaks timing is 30-32 due to numbers gone off of my pulley and a mark was made before they were totally gone. I cant be EXACTLY sure.
"IT IS WHAT IT IS"
