It is currently Mon May 04, 2026 8:55 pm
 Post subject: heim joint verse tree
PostPosted: Mon Apr 16, 2012 1:26 pm
Well after about 40 beers and 3 in the morning :roll: heim joint tensile strength was testedImageImage
PostPosted: Mon Apr 16, 2012 3:35 pm
WoW! Thats a first for me. Never seen a Hiem do that. Had the studs break off on the stud style but never had one peel like a Banana! Chromoly or Carbon steel joint?
PostPosted: Mon Apr 16, 2012 3:58 pm
definitely not chromoly but that's what its getting replaced with...
PostPosted: Mon Apr 16, 2012 4:55 pm
pretty much shattered the tree, lol. He was taking the new Slip Slop for a fun ride and tried to drift in the woods :mrgreen:
PostPosted: Mon Apr 16, 2012 5:39 pm
Rick get 2 from Wade (nc buggy) they will not break .NASCAR tested :wink: and he sell's them right
PostPosted: Mon Apr 16, 2012 6:02 pm
Damn trees! :D :D :D . Chad :mrgreen:
PostPosted: Tue Apr 17, 2012 8:09 am
Just stick another one on and tape two spares to the cage, at least you've got a weak link that just unscrews and replaces in 2 minutes if you do it again :lol:
PostPosted: Tue Apr 17, 2012 2:46 pm
x2
PostPosted: Tue Apr 17, 2012 4:06 pm
To bad it bent the trailing arm were it attaches to the torsion bent the plate the heim screws in to, tweaked a fox shock and broke a cromoly 930 cv cage from binding up
PostPosted: Tue Apr 17, 2012 8:41 pm
I hate weak links!
PostPosted: Wed Apr 18, 2012 8:38 am
Should have made it better then :P
PostPosted: Wed Apr 18, 2012 10:20 am
With an inner and outer heim setup it may have been save-able. Then the inner could have rolled with it?
PostPosted: Wed Apr 18, 2012 6:27 pm
Run a short strap from the torsion housing to the arm. Joint breaks, strap holds it close enough to stop any more damage.
Might find you just snap the bolt with a chromoly joint with it being in single shear?
PostPosted: Wed Apr 18, 2012 6:38 pm
Just drink 39 beers next time and see if that helps make the trees a little less fuzzy,lol. Chad :mrgreen:
PostPosted: Wed Apr 18, 2012 6:42 pm
I like the way this guy thinks!! :D :D lol
"IT IS WHAT IT IS"
