It is currently Mon May 04, 2026 9:53 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 04, 2012 4:22 pm
The bag pivot is this
I will need to check on material prices, the prices changes almost day to day. I will get a quote on something and if I don't buy it today the quote isn't good tomorrow
PostPosted: Sun Mar 04, 2012 6:50 pm
u do pretty good work there mad mike..but i dont have tig welder just mig..looks like its made out of alum..could u make the piece the welds to trailing arm out of steel? and whats some of the benefits over solid mount?..movement of the trailing arm the bag pivots with the cycle?
PostPosted: Sun Mar 04, 2012 7:09 pm
That is made out of alloy steel. Made to be welded to the arms. You are right, the advantage is to keep the bag plates parallel throughout it's travel. I think it makes the installation much easier and the bags work more efficient. I will find out material costs and let you know.
Full droop
Full compression
PostPosted: Mon Mar 05, 2012 4:32 pm
i think im just gonna cut some circles out for air bags mad mike..u do some awesome fab work for sure!!
PostPosted: Wed Mar 07, 2012 10:33 pm
Should reduce wear + tear on the bags too as an extra bonus.
PostPosted: Sat Apr 14, 2012 7:26 pm
welded x brace,got some front tires. mounted shocks, got a center load rack off grand am mounted..thinkn bout not running lines to it..seems steer good nuff to me
http://i396.photobucket.com/albums/pp41 ... e001-3.jpg
got some circles cut and mounted air bags and braced it up and mounted the shocks..need some limit straps..im not sure if i can just mount the limit straps on same bolts as the shocks and that work fine or not?
http://i396.photobucket.com/albums/pp41 ... e002-2.jpg
http://i396.photobucket.com/albums/pp41 ... e004-1.jpg
i added some bracing in the corners
http://i396.photobucket.com/albums/pp41 ... e003-3.jpg
i have the exhaust almost done..im not sure how good its gonna sound..i just dont want it outta control loud..im running 4 into 1 into muffler..and im thinkn bout mounted the radiator in the back engine cradle
PostPosted: Sat Apr 14, 2012 8:52 pm
w would seperate the air lines on the bags. i had mine together into one valve like that and have since made them independant. smoother ride for sure. with them tied together as one bag compresses it pressurises the other.
PostPosted: Sun Apr 15, 2012 1:33 pm
i see exactly what u mean..i might get shrader on each bag..
PostPosted: Sun Apr 15, 2012 2:13 pm
A single shrader and two ball valves after the tee will allow you to get the exact same pressure on each bag, then isolate. Just a thought from a guy without airbags :mrgreen:
PostPosted: Mon May 28, 2012 5:54 pm
http://i396.photobucket.com/albums/pp41 ... 0_0182.jpg
http://i396.photobucket.com/albums/pp41 ... 0_0180.jpg
got some tree bars made
http://i396.photobucket.com/albums/pp41 ... 0_0181.jpg
need some radiator protection..big stick busted some fins not sure how it didnt leak lol..i know damn watercooleds lol
got it going and took it haspins over memorial wkend check stuff out..shocks rub my rear tires and i broke the shock mount sleeve at the top..i dont like the cutter brake location..needs be infront the shifter..pedals need moved couple inches closer to driver lol..and the rack needs some work on toe..oh and my ebay hid lights suck lol..brand new and only 1 works other one just flickers lol..ill be getting some kc daylighters in future..and i want front bumper made before i paint it...i wanted check it out before i get it painted make sure things are how need..but im glad i got drive it around lil bit..project been kicking my butt lol..i hope have it all painted and ready for another ride in a mth or so..been tossing the powedercoating frame idea around alot..
