It is currently Tue May 05, 2026 1:05 am
PostPosted: Tue Apr 10, 2012 8:21 pm
Got a three rib 002 I plan on hooking up on my buggy.
I have a few questions though.
#1 I have read a few times that the input shaft on the 002 is longer than a type 1 trans. I read it as being about 1/2" longer. But when I measure the difference between my two transmissions I get more like an 1/8 difference.
My measuring technique.
#2 which throw out bearing should I use? My 74' sedan bearing (Which is much cleaner, and rolls better), or the one that came on my used bus trans.
There are some minor visible differences.
PostPosted: Tue Apr 10, 2012 8:27 pm
See this album for more close up pictures.
https://picasaweb.google.com/105206047562702661005/Trans?authuser=0&feat=directlink
PostPosted: Wed Apr 11, 2012 1:01 pm
I've got the throw out bearing thing all figured out. So never mind on that question. And I'm pretty sure its the 091 that has a 1/2 long input shaft that needs to be shortened.
http://www.thesamba.com/vw/forum/viewtopic.php?t=148307
PostPosted: Wed Apr 11, 2012 10:31 pm
Same throw out bearing... No mod to the shaft needed.
PostPosted: Thu Apr 12, 2012 12:00 pm
its the 091 shaft that is longer than the 002 or sedan.
