It is currently Sun May 03, 2026 6:28 pm
 Post subject: suby fuel line question
PostPosted: Tue Apr 10, 2012 1:06 pm
anybody know how to make the transition from the steel fuel line on a suby to 6an braided hose.
stock suby uses a hd s.s. clamp on the steel line. the o.d. of the line is 7.94mm or .314"
the id of 6an hose is slightly larger not sure if the clamp would work.
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Apr 10, 2012 2:22 pm
Cut the bump off the end and use a 5/16" OD (.3125") Compression to 3/8" NPT adapter fitting.
PostPosted: Tue Apr 10, 2012 2:55 pm
You can get fuel rail adapters just call summit. They just pop on. And have a 6 an male on the other end
PostPosted: Tue Apr 10, 2012 4:53 pm
Even better Ideal. Did not know they made them.
PostPosted: Tue Apr 10, 2012 6:49 pm
Huh , who would have thought ! ....... Smarty pants 8)
PostPosted: Wed Apr 11, 2012 1:33 am
:lol: I think they make them in 1/4" and 5/16"
That's what I run on my eco
PostPosted: Wed Apr 11, 2012 9:03 am
just purchased it from summit (5/16). also made in 3/8
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Apr 11, 2012 10:17 am
Napa also sells them I picked mine up there I know they have the 1/4 5/16 3/8 but not sure about AN.
PostPosted: Thu Apr 12, 2012 12:06 pm
I just brazed an-6 ends right onto the rail. i cut some old steel fittings apart and drilled the back side to fit over the od of the fuel rail and brzed them up! freebie :mrgreen:
PostPosted: Thu May 31, 2012 9:34 pm
I thought you were the plumber?
