It is currently Tue May 05, 2026 1:58 am
 Post subject: Transmission Question
PostPosted: Sun Feb 26, 2012 8:38 pm
I am building a 1915 with a VZ 15 cam, 041 heads with competition vavle job and dual springs, and weber 40 carbs. I know this motor is gonna cause problems at some point for my current 3 rib. I am looking for suggestions for building a transmission to better suit this motor. Any sueegestions would be great. Also any suggestions on gearing would be helpful as well. Thanks
PostPosted: Sun Feb 26, 2012 8:42 pm
I've always heard 1915 and a 3 rib is a good combo. Run it till it breaks then find something better. Should be ok for a while.
PostPosted: Sun Feb 26, 2012 10:45 pm
youll be fine with that for awhile , i had a 3rib but traded it off before i got to try it with my 1915. my motor sounds damn close to what you have, im runnin a 6rib now no problems. just gotta know how to drive it :mrgreen: :mrgreen:
"IT IS WHAT IT IS"
PostPosted: Mon Feb 27, 2012 12:16 am
the 3 rib will work, but depending on the tire you run, a hot 1915 can over power it...speed is your friend on a hill and a 3 rib jus aint fast enough on a long pull. IMO a 5 rib would be your best bet, they are tough as is and the taller gear will help on the bigger hills. i ran a 5 rib for several years between a mild stroker and 36 buckshots will no problems..of the upgrades i did to that buggy, the 5 rib trans was the best investment
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Mon Feb 27, 2012 10:00 am
if your careful with your foot, a three rib will hold up just fine for years.
