It is currently Mon May 04, 2026 3:55 pm
PostPosted: Sun Feb 26, 2012 7:36 am
jake raby helped in its development and joe gibbs is a big name in racing oil plus it says for aircooled on it, says it can bought through any gibbs retailer after daytona :?
http://shop.joegibbsracingoil.com/cat-34-1-34/DT50.htm
PostPosted: Sun Feb 26, 2012 7:57 am
i currently use castrol 20w 50 but here is a list of other oils also that i would consider
1. castrol gtx - http://www.castrol.com/castrol/productd ... Id=6030785
2. valvoline vr1 - http://www.valvoline.com/products/consu ... motor-oil/
3. brad penn - http://www.bradpennracing.com/
4. joe gibbs - http://www.joegibbsracingoil.com/produc ... index.html
5. royal purple - http://www.royalpurple.com/rp-products.html
6. schaeffers - http://schaefferoil.com/engine_oils.html
7. redline - http://www.redlineoil.com/products.aspx
8. amsoil - http://www.amsoil.com/a/synthetic-motor-oil-engine-oil
PostPosted: Sun Feb 26, 2012 11:32 am
been using brad penn for a couple of years...is the gibbs better? price?
PostPosted: Sun Feb 26, 2012 12:10 pm
Kendall 20-50 is hi in zinc.and $3.89
PostPosted: Sun Feb 26, 2012 2:17 pm
The Kendall used to be high in zinc before the EPA started cracking down on oil companies to reduce emission causing additives in the oils. Brad Penn is what Kendall USED to be. Its made in the same refinery. Brad penn is the best bang for your buck as far as oil goes right now. And to the guys who like to run 20w50....ITS TOO THICK! Thinner oil will lubricate better and run cooler.
PostPosted: Sun Feb 26, 2012 7:15 pm
Last year kendall added zinc back in 20-50 . For racers runing alcohol
PostPosted: Sun Feb 26, 2012 8:41 pm
Millers do a fantastic range of high zinc + moly motorsport oils, and for the cheapskates, their 'classic' range is chock full of ZDDP too, don't know whether you guys get that over there though?
PostPosted: Sun Feb 26, 2012 11:40 pm
I run brad Penn now and have been since motor build! But seems like if I don't change it after a couple good rides "weekends" I'll get a puff of smoke till changed! Mite try this new oil? What y'all think?
Don't let out when in doubt!!
PostPosted: Mon Feb 27, 2012 12:03 am
It sounds like you have a problem with oil dillution and possibly bad ring seal. I don't think the new gibbs oil is going to cure your problem. Besides that, $130 a case is crazy to me!
PostPosted: Mon Feb 27, 2012 12:27 am
Only happens after I'm done rideing and pull it home! When I start it to unload it is when it happens! I think fuel bouncing arOund in carb emptys bowl into cylinders! I'll lett it set for 2 days and won't do it againf
PostPosted: Mon Feb 27, 2012 12:28 am
Think I'll stick with my 5 bucks a qt brad Penn
PostPosted: Tue Feb 28, 2012 11:54 am
15-40 rotella its got zink and not to thick .about 16.00 dollers a gallon.
