It is currently Sun May 03, 2026 11:09 pm
 Post subject: help with rear rotors
PostPosted: Sat Feb 18, 2012 5:59 pm
my buggy has a set of one piece rear rotors and one has stripped the splines out i was told they were bought at auto zone and they come off a porsche? idk and would like to see if anyone knew anything about it
PostPosted: Sat Feb 18, 2012 6:23 pm
As far as I know the Porsche rotors were a two piece, a drive hub and a rotor hat. Sounds like a cheap china made one piece rotor. Is there a spacer between the rotor and the axle nut? If so that's what it is.
PostPosted: Sat Feb 18, 2012 6:36 pm
the axle nut does not sit flat against the rotor it has a shank on it about two inches thick
PostPosted: Sat Feb 18, 2012 6:51 pm
porshe rotors are most all 5 lug patterns also
PostPosted: Sat Feb 18, 2012 7:18 pm
914 was a four bolt, I have a type 3 drive hub that was made to fit inside the Porsche 914 rotor, works rather well. Added; get us a photo, we are shooting in the dark now.
PostPosted: Sat Feb 18, 2012 9:10 pm
Quite a few years back they was a disc brake kit that had solid rotors and was like a hundred bucks cheaper than the next competitors price.can't remember who made them but I know they were extremely heavy.I bought a set at bug stuff but this was years ago,but I'm sure you could still get them but I'd go with the two piece and save on the weight issue myself.don't know what all years but the 924 was also 4 bolt.Chad :mrgreen:
PostPosted: Sat Feb 18, 2012 10:12 pm
Is this what your talking about?
PostPosted: Sat Feb 18, 2012 11:15 pm
yep thats what mine looks like but blue lol
PostPosted: Sat Feb 18, 2012 11:28 pm
Any buggy shop has them. China made one piece rotor. Good luck, have heard of a bunch of them failing the same way.
PostPosted: Sat Feb 18, 2012 11:43 pm
been lookin into the porsche rotor swap may be a better way to go
PostPosted: Sat Feb 18, 2012 11:58 pm
Locate 2 type 3 drive hubs, the outside diameter needs turned down to fit into the Porsche rotor hat works real nice.
PostPosted: Sun Feb 19, 2012 2:16 am
my first buggy originally had the 2 piece rear brake porsche rotor setup and i once stripped the inner splines dues to the axel nut getting loose, we bolted on a stock type 1 drum and jacked both wheels up of the ground and cranked the buggy and put it in 2nd gear and a bungy chord on the other cutting brake and took a side grinder with a cutooff wheel and then held it to the front face of the drum at the same distance from the lug holes as my old one and it looked like a machine shop did it when we got through, kind of a redneck way but it worked fine for us
PostPosted: Sun Feb 19, 2012 9:53 am
what kinda porsche rotors do i need to buy anyone have a part number or price? a type 3 hub is no problem i got some of those
PostPosted: Sun Feb 19, 2012 12:15 pm
I am sure that I'm NOT sure. You will need to do some checking, but some how I seem to remember 1972-76 914 Porsche. Double check this!!
PostPosted: Sun Feb 19, 2012 12:16 pm
Ebay: http://www.ebay.com/itm/porsche-914-4-VW-Rear-brake-disc-rotor-Zimmermann-/280826529820?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item416290c81c
PostPosted: Sun Feb 19, 2012 12:57 pm
Best snag them quick! I surprised myself, My mind aint as messed up as I thought it were.
PostPosted: Sun Feb 19, 2012 2:17 pm
thanks to all the woodsbuggy members for the help fixin to get mine ready for summer
PostPosted: Sun Feb 19, 2012 3:21 pm
Make sure you tighten them with the little tool that ya smack with a BFH . Ive been running the same rotors for 3-4yrs no problems.
"IT IS WHAT IT IS"
PostPosted: Sun Feb 19, 2012 11:18 pm
mine been on about ten years now i guess it wouldn hurt to have somethin new lol
PostPosted: Mon Feb 20, 2012 4:49 pm
Its the five lug rotor hubs that I have seen break like that alot. the inner surface that tightens against the spacer tends to break and then its not flat anymore leading to a wobbley disk and crappy brakes. Most of the 4 lug ones are much thicker right there.
PostPosted: Mon Feb 20, 2012 5:09 pm
What happens is the rotor is made of cast iron, cheap brittle cast iron, If the axle bolt isn't tight enough the fit loosens up between the stub axle and the rotor. The cast iron can't take any amount of hammering and it will eventually fail. The type 3 drive hub is a forged heat treated steel piece, real hard to hurt it. I have seen four or five 4 bolt rotors fail here at Wellsville, Guys think they broke a cv or ring and pinion until someone sees the axle turning and not the wheel. Just like anything else you get what you pay for, garbage in garbage out.
