It is currently Sun May 03, 2026 9:17 pm
PostPosted: Fri Dec 23, 2011 3:19 am
Just Picked up a 16,000 2004 2.2 Ecotec for my buggy!! Only issue is Its a drive by wire and thats why Im here. What do I need to do a cable operated swap? Ive looked all over and have seen info on Cooling, Adapters, and Wiring Optionsbut nothing on theThrottle body swap. I have agreat Tuner in my and Myonly concern is, Is Would I be better off tryin to find a cable throttle Engine to trade mine for or just do the swap?
Let meknow what you guys are thinkin
PostPosted: Fri Dec 23, 2011 8:07 am
Mine was also wire drive if you want to change you need to pick up a new harness and ecu along with cable TB. The new TB will bolt right up but you will need to get 2 new longer bolts.
PostPosted: Fri Dec 23, 2011 9:16 am
They sell a pedal for the drivemby wire if you don't want to mess with swapping everything .
PostPosted: Fri Dec 23, 2011 11:02 pm
Who sell the Pedal Assembly for drive by wire?? I was just thinking the More electronics the better chance for mud and water to mess somthing up.
Thanks Guys for the input!! I appreciate it!
PostPosted: Sat Dec 24, 2011 11:16 am
Enginewireing. Com
I believe that's were Donny bought his , you can pm him if ya need help his screen name is packrat 2056
PostPosted: Sat Feb 18, 2012 12:31 pm
we simply took the throttle body off and switched it to a cable operated one. direct bolt on.
PostPosted: Sat Feb 18, 2012 4:43 pm
The ignition trigger is a different number of teeth which prevents using the earlier 16 bit ECM in place of the newer 32 bit ECM. One option is to retain the original acc. pedal in a waterproof enclosure and cable operate it with a "normal" gas pedal. I used an ammo box wich also houses the ECM and is located close to the engine.There will be tune issues with the DBW such as lag times and decay times of pedal which can be addressed with a custom tune.
PostPosted: Sun Feb 19, 2012 9:21 am
DBW has been proven for crisp throttle response with the right tune.
PostPosted: Sun Feb 19, 2012 12:00 pm
Also to consider is the fact that eventually all cars will be DBW and this means the available donor motors.
