It is currently Tue May 05, 2026 2:04 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
PostPosted: Tue Feb 14, 2012 12:19 pm
Im getting my list together to start riding and i dont wanna be "that guy" who never has the right shit. Heres what Ive got so far
Full set of metric wrenchs and sockets with matching ratchet and two extensions
Good 50 ft tow strap
two quarts of oil
4 gallons of gas
Extra wire
Zip ties
Tape
Tire plugs
Portable air tank
Ether and wd40
5 lb sledge
Lotsa beer
What do you guys carry?
What parts should I carry? I run a 1640 with. 3 rib anwd bus trans, single carb.
Want me hold your purse so you can use the skinny pedal like a man?
PostPosted: Tue Feb 14, 2012 12:45 pm
bus joints
joint bolts
spark plugs
lighter... ether aint no good without one
spare points or elc ing
the list will never be long enough :lol:
PostPosted: Tue Feb 14, 2012 12:46 pm
extra cvs and more beer
PostPosted: Tue Feb 14, 2012 12:47 pm
Axle nut wacking tool or torque dude tool, hex SOCKETS for the trailing arm and cv joint bolts, extra cv joint or better yet a spare axle assy.,brake fluid, first aid kit, small shovel, folding saw that will accept hacksaw and bow saw blades, axle spacer, coil, cotter pins. And find others to ride with, cause nothing will ruin your day faster than being broken down miles from who knows where. DON'T, forget the compass. Ride safley, and thank you for your service to your country. Now, have fun. :idea: :idea: :idea: :mrgreen:
PostPosted: Tue Feb 14, 2012 12:59 pm
At least one of everything,lol.another thing that I carry that wasn't mentioned is a little tbg cutter and farells.farells, never know when you bust a brakeline.if you have one on your buggy at one time or another you'll need a spare.and a small cheater pipe and a small pipe wrench.visegrips.and a rolling wedge bar..chad :mrgreen:
PostPosted: Tue Feb 14, 2012 1:16 pm
Almost forgot, tire irons ?
S&W 357 :wink: :lol:
PostPosted: Tue Feb 14, 2012 1:31 pm
man u guys sure do carry alot lol where do u put it all :lol: :lol: i wanna see some pics of all this stuff on one buggy :lol:
PostPosted: Tue Feb 14, 2012 1:34 pm
air pump and a winch
PostPosted: Tue Feb 14, 2012 2:47 pm
Beer, candy and a good Hooker.
PostPosted: Tue Feb 14, 2012 2:57 pm
If one were to look at the man laws for buggy riding, rule #5 eliminates the need for most of this. But since a bunch seem to ignore rule #5 I carried, and all this fit into a small canvas military ditty bag....
sae combination wrenches 1/4" to 3/4"
Metric combination wrenches from 9mm to 20mm
deep and shallow sockets in trays for both metric and sae
ratchet and different length extensions
two different size vice-grips
two different pipe wrenches
drift punch and chisel
2 lb sledge hammer
Sae and metric allen heads for cv bolts etc.
spare 930 cv and grease
two different regular/phillips screw drivers
black tape
Large channel lock
several small ratchet straps
extra nuts and bolts
crimp-on electrical connections
candy for Brad and a tube of instant glucose, just in case :wink:
Some first aid stuff
If you ride with the same people all the time, if each of you were to carry something different between you and your group, you would have almost everything you would need to fix or at least limp back to the trailer
PostPosted: Tue Feb 14, 2012 3:13 pm
Old bumber jack weld the bottom plate and use u-bolts to hold to tree bar. :wink:
PostPosted: Tue Feb 14, 2012 4:39 pm
Imagehere's a picture. The milk crate has a bit box with 2 of every wrench, socket, ratchet, allen wrenches, screwdrivers needed plus extra tools.light tester,tbg cutter and farells, unions,Crosby wire clamps,extra wheel studs axle nut,nails,wire strippers, snap ring pliers, cheater pipe, pipe wrench, extra shock bolts and a bunch of other little bolts and nuts.also in the crate is a 3" 30' ratchet strap.extra throttle cable, 3lb shop hammer, quart brake fluid, 2 quarts of oil, wedge bar.small chain, long screwdriver, half of machete, little handle saws all, shop rags, and air compressor all strapped in.then in the red bag on top I've got at least 2 change of clothes for me and wife and extra jackets.also have a new bus axle from cv to cv with new bolts.and some other little tools.baby wipes, TP., extra plugs and a coil, set of points and condenser in case electronic ignition goes out, 2 stainless braided brake lines in case tear one off.and some smoke bombs, sparklers, and couple packs of fire crackers, small first aid kit. Behind the seat I carry a 009 stihl saw and a tarp.behind passenger seat I got a 72q cooler that's always full. And anybody that has rode with me can tell you I got it on there lol.I ride by myself almost all the time so if I ain't got it im walking.and im to fat to go far and im afraid to leave kim with the cooler by herself, :shock: lol.and probably alot I forget. Chad :mrgreen:
PostPosted: Tue Feb 14, 2012 5:04 pm
NOT A DAMN THING! i bum it all from people who pass by on the trail! Anyone have an extra bud light and a smoke....and a cv and a tranny and some wires and nuts n bolts....maybe a sandwich. no really though i always take extra smokes, a little debbie,something to drink,a coat hanger and roll of duck tape. and rest of the important stuff goes in diamond daves SOCK.
PostPosted: Tue Feb 14, 2012 6:20 pm
Oh I always got food of some kind,lunch meat or usually get a bucket of chicken,chips and candy.and before the boy out grew the third seat I'd pack him everywhere.should see it when were going camping,lol.Chad :mrgreen:
PostPosted: Tue Feb 14, 2012 6:25 pm
i always have my bbq vienna sausage and some water or mtn dew for food and tools i always have a screwdriver and a pair of pliers cause i have changed my trans in the bottom of windy mtn with that and i have a set of wrenches and sockets and electrical tape and zipties and the cv tool and a quart of oil and i keep atleast 2 cv's on me thats about all i have on me when i go :mrgreen:
PostPosted: Tue Feb 14, 2012 7:50 pm
1/4 3/8 and 1/2 inch ratchets and sockets,metric and standard wrenches, pliers,channel locks and vise grips. various screwdrivers,hammer,allen wrenches,chissel,punch,test light,wire stripper/crimper. all this fits in one ammo box.
Electric wire,small cable,duct tape,electrical tape,small first aid kit,electrical connecters,lug studs and nuts,odd nut and bolts,cv bolts,tire plugs,gloves,etc in another ammo box.
Large pry bar strapped to roof and sometimes a shovel strapped to roof.
high lift jack
4 way lug wrench
winch
winch bag with snatch blocks,chain,50 ft recovery strap,hooks,jumper cables and winch controls.
sometimes a chainsaw
sometimes a spare tire
cooler with beverages,snacks and sometimes herbs :roll:
and gas depending on where i'm at. only a 6 gal tank on car.
PostPosted: Tue Feb 14, 2012 7:59 pm
Tow strap and a good buddy to ride with ! 8)
PostPosted: Tue Feb 14, 2012 8:02 pm
I agree completely! just add plenty beer :wink:
lets just ride
PostPosted: Tue Feb 14, 2012 10:12 pm
A few basic tools and some extra random parts..
Extra Pivot Bolt with wrench
CV Joint and extra CV bolts
Extra Lug Nuts
Cable Ties
Duct Tape
Oil & Brake Fluid (I do not but I think it is a good idea)
Strap and a tie down
MOST IMPORTANTLY .. FOOD... FOOD... FOOD.. It sucks when you go on a 2 hour ride and you get stuck for 8 hours with no food.. Water also helps..
PostPosted: Tue Feb 14, 2012 10:37 pm
depends on where we ride i guess, but always have tools extra cables and cable clamps, spark plugs, lots of beer and cigs,oil, and no one has yet to say it but i carry an extra brand new alt. belt, not so much for charging but for cooling! and hear lately ive seen a few people loose there gland nut off there pulley so that might not be a bad idea, and always a tow strap
PostPosted: Tue Feb 14, 2012 10:47 pm
yea all that and a fan belt :shock: :roll: :lol:
PostPosted: Wed Feb 15, 2012 12:47 am
and a freakin garbage bag tied to the side of my buggy :evil: :evil: well my old lady makes sure of that! the only waste i leave is the shit out of my ass :lol: :lol: dont litter :!:
PostPosted: Wed Feb 15, 2012 1:41 am
i leave is the shit out of my ass :roll: :roll: and watch were you step :lol: :lol: :lol: :lol: yea bring paper towels just in case you step in daves poop :roll: :lol: :lol: :wink:
PostPosted: Wed Feb 15, 2012 1:02 pm
dave is one shittin mofo....he marks his trail so when he gets tipsy he can smell the way back!
