It is currently Mon May 04, 2026 11:27 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: another ?
PostPosted: Fri Jan 27, 2012 9:47 pm
does anyone run a 2cnd gear trans with a 2332 on a 2 seater im wanting to build one and not sure which route to go
 Post subject: Re: another ?
PostPosted: Sat Jan 28, 2012 1:24 pm
What are you trying to decide? and no, I run a 2260cc
PostPosted: Sat Jan 28, 2012 10:30 pm
if i should build it with the stock ratios or build a 2cnd gear trans not sure if the weight of my buggy with my 2332 i would have enough power to pull 2cnd come on guys i need some input on this
PostPosted: Sat Jan 28, 2012 10:42 pm
what kinda two seater.is it gonna built for lightness or built to trail and carry alot of wieght.id say a lower gear would be a lower gear no matter what your pushing.what tire you planning on running? there a few more information probably needed for these ky guys to help ya.chad :mrgreen:
PostPosted: Sat Jan 28, 2012 11:04 pm
Chad I think he is trying to figure out if he will be able to run 2nd gear on hill climbing. Not just if it would be a lower gear for trail riding. At least thats how I interpreted it.
PostPosted: Sat Jan 28, 2012 11:13 pm
ya i want to climb in 2cnd but dont want to build a trans geared for that then not have enough power to pull 2cnd cause then 1st would be way to low to climb in to and 2cnd would be to high for hill climbing. i got a 2 seat beeline polly seats gas tank battery dry sump tank thats about all the extra weight besides the chassis with 4 ply 23 degree flotations on alum. beadlocks
PostPosted: Sat Jan 28, 2012 11:22 pm
if your building it for climbing then id say its not going to weight that much more,maybe couple hundred pounds.id say it would have the power probably.that be like a 330lb guy like i was in a s/s,lol.chad :mrgreen:
PostPosted: Sat Jan 28, 2012 11:29 pm
well in that case it might work lol
PostPosted: Sun Jan 29, 2012 12:31 am
rob herrings two seater is a second gear climber..check "robs wheelie on demand on grass" on youtube
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Thu Feb 02, 2012 12:06 am
yea but i think he runs a 2500 does anyone on here run a 2332 with a 2cnd gear trans
PostPosted: Thu Feb 02, 2012 1:40 am
It will NOT pull it on moderate to bad stuff. You could drive it around just fine probably, but a 2332 just wont pull the gear for hillclimbing. Might "shoot" short straight hills with that combo, but thats about it. A taller first , like a 3.44 (or even a 3.33 if you gonna try to keep it light.), with a decent 2332 will do 10 times better than a 2nd gear trans with a STOUT 2332.
I know its hard to believe that 6mm of stroke would make that much difference in the torque a motor can make and what the optimum gearing for that peak torque range is, but the difference is unreal.
And keep in mind (you may already know this but)..... when you build a true 2nd gear trans, you gotta buy a different r&p too, among other things, not just a gearset. Its about twice as expensive in parts.
No way I would build a 2nd gear unless a 2500 is in your VERY near future.
PostPosted: Thu Feb 02, 2012 7:18 am
Smitty used to run a 2nd gear transmission with his 2276, but he has a very strong engine, I would pm him for that particular question....
PostPosted: Thu Feb 02, 2012 8:01 am
What is the gearing in a second gear tranny? What gear ratio are you running in yours Larry? Just curious what the gear sets are that give it this second gear to run in and how does it compare to a stock 3 rib second gear ratio? Just wondering if anyone can answer this for me.Chad :mrgreen:
PostPosted: Thu Feb 02, 2012 8:25 pm
My opinion is that a well built properly matched 2332 could pull a 2nd gear trans no problem,AS LONG AS THE TRANS WAS BUILT FOR THAT ENGINE.
PostPosted: Thu Feb 02, 2012 9:03 pm
I have heard 5.42rp and some where a round 2.46 2nd ? ? with 2500cc . Larry ???
PostPosted: Thu Feb 02, 2012 9:23 pm
Trans. needs to be build for the eng.tires- buggy - driver and hills or track .
PostPosted: Thu Feb 02, 2012 9:59 pm
Some run a 2.46 some run 2.36, there is a fine line between both of them, I have heard some say 2.36 is a little too fast and uncontrollable, some likes it better than 2.46.....
PostPosted: Thu Feb 02, 2012 10:21 pm
If I was building one I would go with the 311 first 236 second because u can use a 543 r p and pull second or if it is to high for the hill u can still use first Another good reason for these gears is if u brake r p and u can't another one then u can go with a 456 and run first gear and not be but a couple mile per hour slower than ur second with the 543 r p
PostPosted: Thu Feb 02, 2012 10:24 pm
PostPosted: Thu Feb 02, 2012 10:29 pm
i think the only ring and pinion weddle offers for this is 5.14 which is a little higher than the 5.46 but i can go with a 246 2cnd and a 5.14 ring and pinion with a 2332 do you think it will pull it good enough to climb with i want to stop at the bottom and launch it in 2cnd what does my final drive number in 2cnd need to be to do this. with the 5.14 and 2.46 it would be 12.6
PostPosted: Thu Feb 02, 2012 10:30 pm
how strong is that ring and pinion. i was wanting to go with weddle so i no its tough but i dont think they offer that
PostPosted: Thu Feb 02, 2012 10:36 pm
I run a 002 trans with a 2.46 2nd gear and a 5.38 ring and pinion. Im running a 2500 now and pull it with no problem. Im going to put my 2386 on and feel sure that it will pull it fine to. The 5.14 is still gunna be a little tall in my opinion.
PostPosted: Thu Feb 02, 2012 10:40 pm
where can i get a 5.38 or a 5.46 does anyone make them or are they used
PostPosted: Thu Feb 02, 2012 10:47 pm
Mine is 5 rib case with weddle gears and a stock 5.38 ring and pinion.
PostPosted: Thu Feb 02, 2012 11:23 pm
ok i got a stock 5 rib and a stock 6 rib and a side shift with super diff so just put the super diff in the 5 rib with a close ratio first and second or would you put it all in the 6 rib case its an 091 case
